I just ordered all my components for a basic water cooling loop:
12 Feet of Tubing, Blue UV-Reactive PVC (3/8in x 1/2in)
4 pairs Compression fittings (3/8in x 1/2in)
CPU-380I Water Block (Intel Processor)
2 Hose Clamp for OD 1/2in
INS-FM16 Coolant Flow Meter
Flow Meter Frequency Adapter
3 x Delta AFC1212D-PWM 120x25mm Extreme Speed
Black Ice® GT Stealth 360 Highest Performance Radiator
Akasa FLEXA FP5S PWM Fan Splitter Cable
Swiftech MCP35X Pump - PWM Controllable
Swiftech Reservoir for MCP35X pump Revision 2b
This is all going into a HAF XM so I should have plenty of room. The rad will be mounted inside the case above the
motherboard and the full at the top outside of the case.
Two questions:
1) Am I missing anything?
2) What kind of coolant shouldI use. I am wondering if i should just use distilled water with biocide or buy premixed fluid.
Any help would be greatly appreciated.
Thanx Samual
x99-pro/3.1 | i7-5820k | 16gb gskils 3000 | Nvidia gtx 980 ti | 512gb SM950 Pro | Predator 360 AIO | ASUS PA248Q | Seasonic Platnium 1000w
