Results 1 to 10 of 10
Thread: Messed up temps
    ROG Enthusiast Array
    Sep 2012
    28
    Messed up temps
    So, I have an H100 water cooling thingy that I bought, installed 4 Scythe Ultra Kaze's in Push/Pull configuration, stuck an NZXT Sentry Mix on that front bay and hooked up the Scythe fans on it. Thing is, I have to keep the fan controller on the lowest setting all the time, the higher I make the fans spin, the higher the temperature gets on my CPU, WHY IS THAT? -.-
    MIA ROG Guru Array
    May 2010
    14
    1,039
    Quote Originally Posted by Towel View Post
    Thats weird. Don't mean to sound like an A$$ but to me it sounds like the fans are either both pulling or pushing?
    "I would rather be gaming!" Grunts-clan.com
    http://Pcjunkiemods.com
    http://c2cmods.com
    ROG AirWays Captain Array TenBlade's Avatar
    Oct 2012
    45
    815
    Is the intake of air into the case equal to the output, when fans turn at max? If not, you´re creating a relative vacuum, and then less cooling air particles are pushed through.
    ROG Guru: Grand Master Array Arne Saknussemm PC Specs
    Laptop (Model)Laptop?...No way! (Model?...Jun Amaki...yes way!)
    MotherboardROG ZENITH II EXTREME
    ProcessorTHREADRIPPER 3960X
    Memory (part number)TXBD48G4000HC18FBK
    Graphics Card #1GTX Titan X
    Graphics Card #2SLI is dead to me
    Graphics Card #3Tri SLI is even dead to Nvidia
    Graphics Card #4Quad SLI is dead to everybody especially my credit card
    Sound CardXonar Essence STX
    MonitorASUS ROG Swift PG279Q
    Storage #1Samsung 970/960/950 PRO
    Storage #22x OCZ VERTEX 3/2x WD Caviar Black 500GB / 2x WD RED 2TB/Samsung 1TBSSDs
    CPU CoolerCustom Loop: Dual D5s, Dual Alphacool Monsta 480s, XSPC Raystorm Neo TR4, EK TitanX WaterBlock
    CaseNope!...Dimastech Easy XL...let it all hang out man!
    Power SupplySeasonic 1000 Platinum
    Keyboard Corsair Strafe MK2 ROG Claymore... or Fender Rhodes Electric Piano (MKI 73)
    Mouse Corsair M65Pro or Speedy Gonzalez...not Mickey...don't do Disney!
    Headset ...firmly on neck
    Mouse Pad Mouse don't got his own pad man...lives with me
    Headset/Speakers Edifier Spinnaker...or you mean the speakers in my head...man too many voices to name them all
    OS Win XP, 7, 8, 8.1 and Windows 10 Spyware Edition
    Network Router56k modem
    Accessory #1 Umm...nice tie?
    Accessory #2 Err...belt?
    Accessory #3 3 accessories?! I'm not a girl!!
    Arne Saknussemm's Avatar
    Apr 2012
    505
    13,684
    Where is the H100 pump plugged in ? ....a pic might help here....
    Rockford
    Guest
    Ultrakaze pull a fair amount of amp, can your fan controller handle that?
    if its the 3k rpm ones..
    fans on 1 channel?
    ROG Guru: Diamond Belt Array Zka17's Avatar
    Mar 2012
    199
    8,359
    Yeap, some pics would help here... top and bottom of the radiator to see the fans on the H100's rad, and also a pic with the fan controller...
  7. #7
    Dec 2011
    354
    25,742
    Hello
    How are you measuring your temps? What application (or applications) are you using and what are those temps.
    Confirm that the pump of your cooler is actually working please.
    And please indicate the direction of air flow from both fans, I too think you might have the fans pushing against each other. Test this by removing two fans and noting down the temp difference between 4 and 2.
  8. #8
    Sep 2012
    28
    I can't remove them, well, I could but it would be a pain in the ass to get back in as last time I almost destroyed everything in my computer putting it in... Yes, the UK's are the 3K RPM ones, each fan has it's own channel in the fan controller so they aren't sharing. I already know the fans are in push/pull though, and it might just be the stock fans in the case not in-taking enough air the UK's can suck in... The case is a HAF 932, the radiator is mounted at the top, there's also one UK fan at the back exhaust, the door fan and the front fan are stock. Should I replace those? If so, what fans would fit them?
  9. #9
    Rockford
    Guest
    thats 2,4 amp..
    You need a heavy duty fan controller, to run them on 1 single channel..
    Or else, its just a matter of time, before your controller will go up in smoke..
    Ok 1 on each channel.. 0.60 amp X 4
  10. #10
    Sep 2012
    28
    Quote Originally Posted by X Pack View Post
    thats 2,4 amp..
    Huh...? The Sentry Mix is 50W per channel, the Ultra Kaze's are 7.2W each fan, which means that I could put up to 6 fans on one channel... I just can't find a 3-Pin Y splitter to attatch 2 fans or more to one channel.
