Results 1 to 9 of 9
    ROG Guru: Yellow Belt Array
    Aug 2012
    20
    125
    Problems with Wow
    I have been running World of Warcraft for several years with no problems. A couple of days ago I tried logging on and it came to a blue screen that said critical error. I looked and my Nvidia 8800 GT ( I know I am behind ) had a driver update available. I downloaded the new driver, logged in and played that afternoon with no problems. Since logging out that evening I cannot log back in, it keeps giving me the blue screen saying critical error. No other programs or internet has any problem, they work fine, and blizzard dosent know of any problems. My friends can log on and play fine. I also downloaded Dead Space 2 and after downloading it will not play, it starts to load then says this program needs to close. Anyone have any ideas, the only thing hardware related i have noticed is that my gpu fan stopped working about a month ago and I have to enter nvidia n tune and turn it on manually. Could this be a graphics card going bad.
    ROG Guru: Grand Master Array Arne Saknussemm PC Specs
    Laptop (Model)Laptop?...No way! (Model?...Jun Amaki...yes way!)
    MotherboardROG ZENITH II EXTREME
    ProcessorTHREADRIPPER 3960X
    Memory (part number)TXBD48G4000HC18FBK
    Graphics Card #1GTX Titan X
    Graphics Card #2SLI is dead to me
    Graphics Card #3Tri SLI is even dead to Nvidia
    Graphics Card #4Quad SLI is dead to everybody especially my credit card
    Sound CardXonar Essence STX
    MonitorASUS ROG Swift PG279Q
    Storage #1Samsung 970/960/950 PRO
    Storage #22x OCZ VERTEX 3/2x WD Caviar Black 500GB / 2x WD RED 2TB/Samsung 1TBSSDs
    CPU CoolerCustom Loop: Dual D5s, Dual Alphacool Monsta 480s, XSPC Raystorm Neo TR4, EK TitanX WaterBlock
    CaseNope!...Dimastech Easy XL...let it all hang out man!
    Power SupplySeasonic 1000 Platinum
    Keyboard Corsair Strafe MK2 ROG Claymore... or Fender Rhodes Electric Piano (MKI 73)
    Mouse Corsair M65Pro or Speedy Gonzalez...not Mickey...don't do Disney!
    Headset ...firmly on neck
    Mouse Pad Mouse don't got his own pad man...lives with me
    Headset/Speakers Edifier Spinnaker...or you mean the speakers in my head...man too many voices to name them all
    OS Win XP, 7, 8, 8.1 and Windows 10 Spyware Edition
    Network Router56k modem
    Accessory #1 Umm...nice tie?
    Accessory #2 Err...belt?
    Accessory #3 3 accessories?! I'm not a girl!!
    Arne Saknussemm's Avatar
    Apr 2012
    499
    13,575
    That fan bit doesn't sound too good but it might not mean it is the card this can happen with RAM problems too. I would memtest the RAM, error check your drives etc too.
    ROG Guru: Orange Belt Array PlaneName's Avatar
    Mar 2012
    21
    250
    Hey immaturegizzmoe,
    Download this:
    http://www.nirsoft.net/utils/blue_screen_view.html
    When the BSOD appear let it do the physical memory dump, so BlueScreenView identify which file is corrupted. When you have BlueScreenView downloaded, installed, open the application. If BlueScreenView not showing any minidump files, make sure to play WoW and wait for the BSOD and let it finishing creating the memory dump file.
    After that, they will show the corrupted files by showing the red-highlighted bars. Just tell us those files and the error, then we will know where to go from there. It's better to go into the Windows forums (What is your OS first of all?) to get more help from there.
    Case: Antec 300 Mini Tower Motherboard: GA-Z68A-D3H-B3 (rev1.3) CPU: i5 2500k @ 4.5ghz Cooler: Hyper 212 EVO GPU: GIGABYTE GTX 560ti (950mhz) RAM: G.Skill 8 GB DDR3 @ 1600mhz PSU: Corsair CX 750 Driver: 320.00
    Been building PC's for 8 Years!
    Aug 2012
    20
    125
    Quote Originally Posted by Arne Saknussemm View Post
    thanks, will try that.
    Aug 2012
    20
    125
    Quote Originally Posted by PlaneName View Post
    Download this:
    I will try this, thanks. I am running windows vista service pack 3
    Mar 2012
    21
    250
    Very nice! don't forget to tell us how it went! if you know what to do from there, that's when you should finally know what is the error and do some searching on the windows forums for that error. I've been getting allot of BSOD's and the windows forums helps me allot and I'm memorizing most of the error's that I have been through :P.
  7. #7
    Enthusiastic Youngster Array MrRyaz's Avatar
    Mar 2012
    20
    64
    i have had problems with wow before but from your description it sounds like its all games?
    the problem i had was with an OC on my old system where the RAM was not 100% stable and as WOW uses a lot of ram ( back in those days) and caused bluescreens & crashes. So i would try memtest like Arne Saknussemm suggested
  8. #8
    ROG Guru: Green Belt Array mrwolf's Avatar
    Jun 2012
    21
    657
    Im surprised people still play wow.. Havnt you guys got bored of that after so many years lol? and graphics are olldd skoool !
    You guys should give guildwars 2 a try
  9. #9
    Mar 2012
    20
    64
    i dont mean to turn this into a gaming discussion but i played GW2 for a bit but i went back to wow, graphics and game mechanics arnt everything im gaming...
