11-06-2012 08:51 AM - last edited on 03-06-2024 06:29 PM by ROGBot
11-06-2012 10:42 AM
11-06-2012 12:16 PM
Arne Saknussemm wrote:
You could download an OCing program like Afterburner and downclock the card a bit to test out if it is stable at lower clocks. If so then you will have to send it back since it is not doing what it is supposed to. And it does sound like the OC is failing.
11-06-2012 12:46 PM
11-06-2012 01:28 PM
GPU tweak is volatile (to put something polite) at the best of times. No, that isn't supposed to happen.....you just moved the slider for core clock down a bit?. I would run GPU tweak and click defaults.....exit and uninstall it. Use AB or Precision X.
11-06-2012 01:33 PM
11-06-2012 01:58 PM
HiVizMan wrote:
Download the latest version of GPUz.
Open the appliction and click on the monitoring tab. Tick the box at the bottom that enables monitoring when application is in the back ground.
Post a screenshot of the open GPUz and monitoring page after you have let your card do its thing for 10 mins or so. Watch a video or play a game for 10 minutes. Do not run a benchmark please.
I want to see the temps so make sure you scroll the monitoring page up.
11-06-2012 02:08 PM
Krazye wrote:
I've uploaded the screenshots, please let me know what u think. Tks
11-06-2012 02:17 PM
HiVizMan wrote:
OK so it seems to be reasonable.
Can you post a GPUz main tab now please.
11-06-2012 02:26 PM
