11-11-2012 05:40 AM - last edited 3 weeks ago by ROGBot
11-11-2012 10:35 AM
wistryker wrote:
I am having the same problem on a G73. The fans run at 100% from the dtart up and never slow dawn at all. Trying to find out also what to do to cure the problem.
11-11-2012 10:45 AM
11-11-2012 11:33 AM
11-12-2012 03:16 AM
Zygomorphic wrote:
I own a G53SX and have never had problems with it. The fans are never that loud, even when playing games like Quake IV. Hope that it fixes it for you. It is possible that the fan controller got confused and pulling the battery cleared it. :confused:.
11-12-2012 06:31 AM
11-12-2012 08:53 AM
phandaal wrote:
I've been having this same issue as well. Internal temps are 39-40C, fan on at 100% constantly.
11-12-2012 09:33 AM
dstrakele wrote:
How have you determined your fan is running at 100% ? I've noticed on HWINFO64, one sensor reports the GPU Fan at 100% all the time, but the EC Sensor, which reports both CPU and GPU Fan speeds in RPM, has accurate values that indicate much less. 100% Fan Speed is 3500+ RPM.
11-15-2012 02:03 PM
