Page 1 of 2 1 2 LastLast
Results 1 to 10 of 11
    Happydude666
    Guest
    OCing issues with M4E + 2600K + SLI 460 GTX
    Hi everyone,
    I recently got and setup my watercooled build with 2 EVGA 460s in SLI, a 2600K and the M4E board along with 8GB (2x 4GB) of G.Skill Reaper X RAM. I am also using a Corsair 850AX PSU (which should give me more than enough power).
    The issues I'm coming across are a little odd and not something I can figure out on the own, so I'm coming to you.
    I was able to OC my GPUs to EVGA's 'FTW' standard on those cards. While keeping my CPU at stock speeds, I ran all sorts of tests as well as 3DMark Vantage with no issues.
    Once I OC the CPU to 4.2GHz (using the auto OC setting in BIOS), the GPUs overheat and can't get through a single test.
    So I need some advise on troubleshooting the issue. Is this an issue with a lack of power going to the cards once the CPU uses more?
    Let me know what you guys think.
    TeamROG Moderator Array xeromist PC Specs
    xeromist PC Specs
    Laptop (Model)Dell Inspiron 15 7567
    MotherboardMSI x470 Gaming Plus
    ProcessorAMD 2600X
    Memory (part number)16GB Crucial Ballistix Elite 3600
    Graphics Card #1ASUS GTX 1080 Strix
    MonitorBenQ BL3200PT
    Storage #1Intel 600p NVMe
    CPU CoolerWraith
    Casecustom Antec 900
    Power SupplyCorsair HX1000
    Keyboard Logitech Orion Spark
    Mouse Logitech MX500
    Headset Plantronics 777 with Oregon Aero upgrade
    xeromist's Avatar
    Jul 2010
    318
    7,763
    Are the GPUs on the same loop as the CPU?
    * Support disease research with Folding@Home *
    < < < Click the drop-down above my avatar for my PC specs!
    MIA ROG Guru Array
    May 2010
    14
    1,039
    As far as I know what X asked would be the only cause for overheating. One loop? How many rads? how is your watercooling setup?
    "I would rather be gaming!" Grunts-clan.com
    http://Pcjunkiemods.com
    http://c2cmods.com
    Happydude666
    Guest
    Hey guys,
    Sorry for the delayed response. Been busy with all these issues and other things that I completely even forgot I posted the issue here -_-
    Anyway, after some extensive testing (taking apart my entire loop and going on air for a little bit, then connecting the loop with individual components, I figured out that one of the GPUs is simply bad. It over heats even at stocks speeds, I just didn't notice (somehow). One of the cards works great, and runs at a cool 38C at 100% load, while the other runs to >80C at heavy load and stock speeds.
    I'm just RMAing it.
    But to answer your questions:
    It is a single loop with a XSPC RX360 rad with 3 Gelid 120 PWM fans.
    xeromist PC Specs
    ProcessorAMD 2600X
    CPU CoolerWraith
    xeromist's Avatar
    Jul 2010
    318
    7,763
    Sounds like that card isn't making good contact with the heat sink. If you can RMA then I guess that's good but you probably could have solved it yourself with repaste and heat sink adjustment if you didn't want to wait.
    Happydude666
    Guest
    I did. I replaced the heatsinks on it 3 times. and repasted each time. 2 times with the water block and once with the air. All 3 times, the temps did not improve. I highly doubt it was just a bad contact.
    EVGA already approved on RMA on the card, so I'm just going to do it that way.
  7. #7
    xeromist PC Specs
    ProcessorAMD 2600X
    CPU CoolerWraith
    xeromist's Avatar
    Jul 2010
    318
    7,763
    Ah, that sucks. Well at least you tried and at least you can RMA. Hope the next one works out better for you.
  8. #8
    Happydude666
    Guest
    Thanks for the suggestions.
  9. #9
    Happydude666
    Guest
    It's up and running!!! (Finally) Had to RMA a GPU and reinstall windows about a dozen times to figure out the software conflict issues.
    http://www.modsrigs.com/detail.aspx?BuildID=27078
  10. #10
    xeromist PC Specs
    ProcessorAMD 2600X
    CPU CoolerWraith
    xeromist's Avatar
    Jul 2010
    318
    7,763
    Glad it's finally working
Similar Threads
  1. 2600k on dry ice
    By pcjunkie209 in forum Overclocking & Tweaking
    Last Post: 07-01-2011, 04:11 AM
  2. Unboxing of Sabertooth P67 & 2600K
    By pcjunkie209 in forum Other Series Motherboards
    Last Post: 03-18-2011, 01:55 PM
  3. 2600k vs 980x?
    By glw165 in forum Other Series Motherboards
    Last Post: 01-06-2011, 11:27 PM
  4. New to Rampage and OCing
    By Victus in forum Other Series Motherboards
    Last Post: 08-19-2010, 08:46 PM
