Results 1 to 3 of 3
    ROG Enthusiast Array Spydyr's Avatar
    Nov 2012
    58
    G75VW Wifi light
    I bought this beast to replace my G73SW that died. Because I could not use Win 8 because of software issues I loaded up Win 7 Ult. Installed all Win 7 Asus software and drivers. I know some see it as a waste but compared to other companies Asus doesn't have Bloat. I have the Atheros AR9485 Wireless card but I also still have the Intel Wifi card from my G73 if i need it. Anyway my Wifi light is not coming on anymore. Does it have something to do with the fact that I went from Win 8 to Win 7 or am I just missing something.
    Specs.
    Model: G75VW-BHI7N07
    CPU: i7-3630QM (This is not a typo BIOS, CPUZ, and AIDA64 all confirm)
    Memory: 12 Gig (stock 8 Gig)
    HDD: 1 TB (Stock)
    ODD: DVD Burner (Stock)
    Gfx: GTX 660M (Stock)
    Wireless: Atheros AR9485 (Stock)
    Wired: Stock (turned off)
    BIOS: 221
    If there is anything else anyone needs just.
    Spydyr
    New ROGer Array
    Oct 2012
    13
    2,441
    HI, Did you mean when you update to Win8, Wifi have no function? Did you install Win 8 Driver form ASUS website and please check device manage are no exclamation mark or any error message.
    Nov 2012
    58
    No I removed Windows 8 it is not business friendly in my line of work. From what I have messed with on windows 8, Windows 7 is still for businesses and none touchscreens. As far as wireless console no I have not tried that one because I though it was for Intel wireless cards only but I am going to give it a shot right now.
    Spydyr
    Edit: Nope did not fix it. It is not that big a deal i would just like it working.
