Results 1 to 10 of 10
    ROG Guru: Yellow Belt Array Black4 PC Specs
    Black4 PC Specs
    MotherboardStrix B550-F
    ProcessorRyzen 3 3300X
    Memory (part number)G.SKILL Flare X (for AMD) 16GB DDR4 3200 (PC4 25600)
    Graphics Card #1Gigabyte GTX 970 G1 gaming
    Graphics Card #2Asus DUAL RX580
    MonitorAsus VG278Q 1ms 144Hz
    Storage #1WD BLACK SN750 NVMe M.2 500GB
    Storage #2Seagate 1TB 64MB Cache SATA 6.0Gb/s 3.5" Internal
    CPU CoolerGammax 400GT air
    CasePhanteks Enthoo Evolv X
    Power SupplyASUS ROG Strix ROG-STRIX 550W 80 Plus Gold
    Keyboard Corsair K70 Mechanical, Cherry MX red
    Mouse G502 SE Hero
    Headset HyperX Cloud Alpha Pro Gaming Headset
    Mouse Pad Alienware
    Headset/Speakers Logitech Z533 multimedia speakers
    OS Windows 10 home 64 bit
    Black4's Avatar
    Mar 2012
    11
    189
    Painting a Case Camouflage
    Given the popularity of fps military games, I suspect someone else has custom-painted a case camouflage.
    I'd consider painting a green or white Corsair Vengeance C70 case camo woodland or winter camo, if I could get a clean and durable paint finish from it.
    Anyone know of any techniques for painting camo that I could apply to this case?
    A Republic of Gamers heart.
    The all-new Subaru WRX is coming. Pardon our dust.
    AntiMatter Guru ROG Array chrsplmr's Avatar
    Jul 2011
    295
    6,113
    Here is some 'work logs' from one of our favorite Mod'r's ... MonsterMawd .. maybe
    you will get some ideas .. c.
    http://www.mnpctech.com/casemodblog/...3-pc-case-mod/
    http://www.mnpctech.com/casemodblog/...r-pc-case-mod/
    http://www.mnpctech.com/casemodblog/...amo-case-mods/
    You could also try Video HowTo Searches .. ie ..
    http://www.youtube.com/results?searc....1.OOmr1RBzfLg
    ROG Guru: Black Belt Array Area 66's Avatar
    Jun 2011
    49
    2,276
    Hi, the one you show on the pic have a very distinct edge between the colour, it can be done with a stencil and a spray can. But usually camouflage have a more cloud edge look, in that case you need a dual action airbrush to make those kind of fuzzy edges between colours. Painting with an airbrush need a lot of practice, I will suggest to deal with someone who do this king of work.
    Black4 PC Specs
    Mouse G502 SE Hero
    Mouse Pad Alienware
    Black4's Avatar
    Mar 2012
    11
    189
    This is great feedback guys, and thanks for the links. I especially like the overall look of the BF3 tribute case. These modders are incredible.
    Jul 2011
    295
    6,113
    There are Mod'r's of all flavors here .. another is pcJunkie209 .. not to leave anyone out .. they are
    all so awesome .. go peeking .. 'they' don't mind .. hahahhahaa ..
    imMortal Kombatant Array Myk SilentShadow PC Specs
    MotherboardASUS Rampage IV Formula
    ProcessorIntel i7 3930K
    Memory (part number)8GB Corsair XMS3 1600
    Graphics Card #1ASUS Radeon 7970 3GD5
    Sound CardROG Xonar Phoebus
    MonitorSamsung SyncMaster SA300
    Storage #1Corsair Neutron 128GB
    Storage #2Seagate 2TB
    CPU CoolerCorsair A50 Pro Air Cooler
    CaseBitFenix Merc Alpha
    Power SupplyThermaltake Litepower 700W
    Keyboard Alienware TactX Keyboard
    Mouse Tesoro Gandiva H1L
    OS Win7 Ultimate x64
    Myk SilentShadow's Avatar
    Jan 2012
    266
    5,241
    Go for a Winter Cammo look, haven't seen a build with that color scheme yet and to me, the standard cammo green is just so over done
  7. #7
    New ROGer Array Zygomorphic's Avatar
    Mar 2012
    176
    4,761
    That's an awesome case design! Post pics when you get it done! My advice would be stencils if you want the clean edges. If you create the design on the computer and print each piece out on a separate piece of paper and cut it out, you could get some nice clean lines.
    I am disturbed because I cannot break my system...found out there were others trying to cope! We have a support group on here, if your system will not break, please join!
    http://rog.asus.com/forum/group.php?groupid=16
    We now have 178 people whose systems will not break! Yippee!
    LINUX Users, we have a group!
    http://rog.asus.com/forum/group.php?groupid=23
  8. #8
    Mar 2012
    176
    4,761
    Quote Originally Posted by Jenfrag View Post
    At a first glance, it doesn't look like a CPU case.. It looks like one of the military's things.
    For playing Battlefield 3 on a battlefield without being seen...
  9. #9
    Jul 2011
    295
    6,113
    I always thought that the perfect camo would be to Mod the System around the
    'desk environment' (perferably a corner) .. taking a pic of the 'desk' with and without
    the system .. then paint the 'system' to match the 'placement in the pic without' ..
    if you follow my 'drift' .. matching the entrance/doorway 'first view' angle ....
    only when you move off center will you see the system (other than the blackness of the monitor screen)
    with a little '3D'n' imagination .. the side angles could be 'duplicated ..maybe spinning like infinity mirrors'..
    hahaha ...
    i know this misses the point of camo as in a combat game ... but its sys camo ..
    sorry .. was just typ'n out loud ..c.
  10. #10
    ROG Guru: Orange Belt Array Granger PC Specs
    Granger PC Specs
    MotherboardROG STRIX X570 E-GAMING
    ProcessorRyzen 7 5800X
    Memory (part number)Patriot Viper 32GB @ 3600
    Graphics Card #1RX480 8GB 0C
    MonitorSamsung
    Storage #1Samsung SSD 970 M2
    Storage #2250gb SSD + 750 GB SSD + 4 HD 3Tb total + NAS 3Tb
    CPU CoolerEK custom loop
    CaseThermaltake CORE X9 Snow
    Power SupplyCoolermaster SilentPro Hybrid 1300W
    Keyboard Razer Black Widow Ultimate
    Mouse Razer Ourobouros
    Headset Sony MD1
    Mouse Pad Razer
    OS Windows 10
    Network RouterISP provided (Free)
    Accessory #1 Razer Hydra
    Accessory #2 Madcatz Arcade Fightstick
    Accessory #3 Belkin n52te
    Granger's Avatar
    Dec 2011
    25
    420
    For the paint, you can use a decent acryllic paint, then use a mat varnish to protect it, my nephew has just done the side panel on my pc and its great.
Tags for this Thread
