I'm in the market for a Notebook cooler. I have read some reviews and posts about different ones but mostly for the JH /W models and I don't know if what is said about them can be applied to the SW.
When I purchased my G73 I also picked up a CoolerMasters SF19 (usb2 v.) and currently unsure about it so would like some personal feedback on other coolers for my needs / likes.
- I'm not fond of the incline on the SF19, would like something that isn't so thick.
- Plugged in it is quite loud, because of this I just have it on USB most of the time.
- Like the USB hub.
While I was looking around it seems that one big fan is better then little ones because of more CFM and less power needed. (If this isn't correct someone please let me know.)
The current coolers I am looking at (to replace the SF19) are the
Zalaman NC3000U and the
Thermaltake Massive23 LT I'm leaning more towards the Massive23 because it seems to be the better deal and the Zalaman doesn't seem to be any better.
If the Zalaman is better and worth the 20$ more please let me know.
If there is some other Cooler I should consider please post.
Any help is greatly appreciated.
For people that like stats...
Zalaman NC3000U
Dimensions: 14.37" x 15.75" x 2.36" (365(L) x 400(W) x 60(H) mm)
Weight: 2.64 lbs. (1.2kg )
Materials: Aluminum, Plastic
Fan: 220mm/Axial Fan
RPM: 620~720rpm ± 10 %
Noise: 17~23dBA ± 10 %
CFM: 39.2 at 620rpm (3.4V) 45.4 at 720rpm (4.2V)
3 USB Ports
Heatsink Dimension: 14.8" (L) x 11.81" (W) x 2.03" (H) 376 (L) x 300 (W) x 51.5 (H) mm
Weight: 900 g / 1.98 lb
Materials: Aluminum & Plastic
Fan Dimension: 200 x 200 x 20 mm
Fan Speed: 600 ± 10% RPM
Noise Level: 17 dBA
CFM: 54.6
Max. Air Pressure: 0.32 mmH2O
2 USB Ports
