Results 1 to 7 of 7
    ROG Member Array
    Oct 2012
    6
    G75VW performance problem
    Hi guys,
    I play this game DotA2, when I bought the laptop I played at 120 fps (which is the max) but now I can only play between 70 and 90 fps I do not know what happened, do you guys have any idea what might cause this problem ?
    With this notebook i should be able to play the game to max fps.
    Specs:
    I7-3610Qm 2.30GHz
    16 RAM
    Geforce GTX 670M - 3GB
    SSD 256 GB
    ROG Guru: Black Belt Array rewben PC Specs
    rewben PC Specs
    Laptop (Model)G55VW-3D
    MotherboardASROCK Z97 EXTREME 6
    ProcessorINTEL 4790K
    Memory (part number)G.SKILL RIPJAWZ 2400MHZ (F3-19200CL10Q-32GBZHD)
    Graphics Card #1ASUS STRIX-GTX980-DC2OC-4GD5
    Graphics Card #2ASUS STRIX-GTX980-DC2OC-4GD5
    MonitorDELL U2713HM
    Storage #1SAMSUNG SM843 480GB X2
    Storage #2WD GREEN 3TB X2
    CPU CoolerSWIFTECH H240-X
    CaseNZXT H440
    Power SupplyTHERMALTAKE TOUGHPOWER XT PLATINUM 1275W
    Keyboard CORSAIR K70 RGB
    Mouse STEELSERIES KINZU V3
    Headset STEELSERIES 9H
    Mouse Pad STEELSERIES QCK+
    Headset/Speakers LOGITECH Z506
    OS WINDOWS 10 PRO AU
    Network RouterASUS RT-AC66U
    Jun 2012
    178
    2,229
    perhaps you can furnish answers to the questions below first:
    1. what's your brand of the SSD?
    2. how much is the space left in it?
    3. do you use antivirus? what is it?
    ROG Member Array
    Oct 2012
    6
    1- dont know it came with the laptop
    2- 130gb
    3- Avg free
    ROG Enthusiast Array Sqnkov's Avatar
    Sep 2012
    15
    34
    It is deffinateley a software or internet connection problem since Dota2 is online playable only.
    ROG Guru: White Belt Array
    Feb 2011
    12
    110
    I agree with Sqnkov on the potential problems, but you do realize that your eyes literally cannot see the difference once you hit 60 FPS right? If you are above 60 FPS, you should have absolutely no issues.
    You could run 3dmark though and share your results and someone else with a 670m could chime in to confirm that your benchmarks look ok. That'd honestly be the only recommendation I'd make here. Also make sure you're running on high performance power management profile because anything else can throttle video performance a bit.
    ROG Guru: Blue Belt Array
    Apr 2012
    23
    878
    Yes,try to set power management mode from nvidia contol panel
    under the link for your reference:
    http://nvidia.custhelp.com/app/answers/detail/a_id/3130
  7. #7
    ROG Member Array
    Oct 2012
    6
    Thank you for all the answers guys im gonna try that
