Results 1 to 10 of 15
12-12-2012 06:40 PM #1
- Join Date
- Mar 2012
- Reputation
- 10
- Posts
- 85
Help! Low +12V, On-Off Restart Issues
Was just browsing a while ago when my PC suddenly restarts. To my surprise it went back on and nothing displays on screen. Checked the inside of my RIG to see the fans connected to the motherboard not working and I guess the entire motherboard is not working as well. Then it was restarting after a few second interval
What's going on!?!?!
This might be helpful
the +12V section reads 7.08V only.. X_______X
Is that normal or significantly low???
I don't remember that being like that.
Please help!
I'm using an ASUS P8Z77M-PRO
please see cpuid sig for specs
Intel i5-2500k - ASUS Maximus V Gene - ASUS GTX 660 DCU II
ASUS ThunderFX - Be Quiet Dark Power Pro 10 850w
OCZ Vector 120GB - Corsair H90
Corsair Vengeance 2x4GB - Coolermaster Storm Trooper
12-12-2012 07:11 PM #2
- Join Date
- Jul 2012
- Reputation
- 68
- Posts
- 764
I would call that significantly low. +/- ~0.5V wouldn't be a big deal, but we're talking about -5V. First thing I'd suggest doing is putting in a new PSU, as that's the most likely culprit. If you're still getting the same issue with a new PSU, then it'd be time to RMA the board.
12-12-2012 08:29 PM #3
That is hardware waiting to be damaged. Me I would not use that PSU on my system.
12-13-2012 12:18 AM #4
- Join Date
- Mar 2012
- Reputation
- 10
- Posts
- 85
I was using this PSU (Corsair TX650) for 10 months now. I don't remember it being like this.
So it's the PSU? I think somethings is wrong with it. This was just recent... I am getting screen freezes from time to time too
12-13-2012 12:43 AM #5
- Join Date
- Jul 2012
- Reputation
- 68
- Posts
- 764
12-13-2012 12:55 AM #6
- Join Date
- Mar 2012
- Reputation
- 10
- Posts
- 85
Okay, thanks for all your help guys. Fortunately both the mobo and PSU is from one dealer and he's really easy to talk to. I think I'll just head there.. I'm really confused.. I installed a generic 500w PSU, same thing occurred but since it was an old backup I can't really make a clear conclusionIntel i5-2500k - ASUS Maximus V Gene - ASUS GTX 660 DCU II
12-13-2012 10:58 AM #7
- Join Date
- Mar 2012
- Reputation
- 10
- Posts
- 85
I had it checked, they spent the entire day checking everything and found that it was the motherboard
It was like the motherboard had a stroke, some of the headers aren't working and wasn't supplying enough power to the processor says the dealer's technician.
Anyway, It was still 6 months old, it was sent for RMA now.Intel i5-2500k - ASUS Maximus V Gene - ASUS GTX 660 DCU II
12-13-2012 06:15 PM #8
- Join Date
- Jul 2012
- Reputation
- 68
- Posts
- 764
Well, the important thing is that you found what the issue was. I'm honestly a little surprised the unit would boot and run at all with just a bit over half the voltage it was expecting. Anyway, it might not be a bad idea to kind of stress test other components, like PCIe cards and RAM, when you get your replacement. Anything that would have been drawing power from the main 12V rail you will want to check. Hopefully everything comes out fine, but it's possible there's some collateral damage.
12-14-2012 06:11 AM #9
- Join Date
- Mar 2012
- Reputation
- 10
- Posts
- 85
12-15-2012 12:21 AM #10
- Join Date
- Jul 2012
- Reputation
- 68
- Posts
- 764
I'm no EE, but I'd say you suffered a capacitor failure or two. Some component, or components, that help regulate the voltage on the 12V rail failed. So you were probably getting some rather large fluctuations in the voltage coming down that line, hence why you want to make sure to test anything that gets power off that rail. Good news is, someone will probably be able to fix it when it gets back to an RMA center.
