12-12-2012 07:33 PM - last edited on 03-06-2024 06:33 PM by ROGBot
12-12-2012 07:44 PM
12-12-2012 07:49 PM
12-12-2012 08:51 PM
dstrakele wrote:
The ASUS Factory Recovery process from DVD typically takes about an hour and 45 minutes, rebooting the laptop several times. ASUS Factory Recovery from the hidden partition on your HDD, accessed by pressing F9 at startup, takes about an hour, also performing multiple reboots.
If you interrupt the process before completion, it may result in the behavior you report. When completed, the recovery should leave you at the Windows 7 Setup Wizard screen.
12-12-2012 09:55 PM
dstrakele wrote:
Are you removing the Recovery DVD before you select your language in Windows Setup?
12-12-2012 10:04 PM
12-12-2012 10:15 PM
dstrakele wrote:
How long had the Recovery process run before you entered your language?
Did you let the laptop remain at the Windows Setup Wizard screen for at least 10 minutes before touching it?
12-12-2012 10:44 PM
letapecul wrote:
well, from bootup until entering language it is only running for a minute or two. also, i have not gotten to any windows setup wizard screens, only the asus preload wizard. i tried the recovery disc last night, let the whole process run, then didnt touch anything. i ended up at the asus preload wizard, and i let it sit on the language selection screen for an hour, but nothing happened
