WiFi combo card
thestillwind
I search but didn't find the answer I was looking for. I want to know where can I buy the WiFi combo card included in the Maximus V Extreme mobo. It might be kinda lame, but I would like to get the Asus-ROG branded version if I can.
Currently my mobo is the Maximus V Gene so there is no problem with fitting it.
Thanks in advance
5 REPLIES 5
Chino
Level 15
I don't think they sell the MPCIe card separately. Your best bet would be to look on Ebay. Just search for "ASUS MPCIE COMBO". 😉
SUKARA
I suggest you can help to contract asus service centert about this
asus service center contact infotmation:
http://support.asus.com/Hotlines.aspx?SLanguage=en
thestillwind
Thanks I'll check for this. I think I found the WiFi card alone.
evilmustang66
asus store under other has them
I have an extra one, shoot me a resonable offer its brand new never used and has the rog brand on it 😉
