Results 1 to 5 of 5
    New ROGer Array
    Jun 2012
    4
    Exclamation G72VW (670M) - Temperature question
    Hello lads!
    I was playing Far cry for a few (~15minutes) and th GPU reached a temperature of 96-98 degrees Celsius, are there any reason for concern? I am not overclocking the GPU. Idle temperature is 65 degrees Celcius
    Oops sorry it should be G75VW of course!
    ROG Guru: Orange Belt Array ggBanks's Avatar
    Sep 2012
    21
    365
    That is wickedly high temps for idle mode!!! My temperatures while gaming top at 70C, and this is in rare occasions. You definitely need to change your thermal paste and clean the laptop, or if you don't know how to do it, just give it to ASUS service, so they can fix it for you!
    New ROGer Array
    Jun 2012
    4
    I've done it before on stationary pc's. Will the warranty be voided if I open the chassi and attempt to do it myself?
    New ROGer Array
    Jun 2012
    4
    I did some vacuuming around the fan now and idle temp dropped from 64-67 down to 54-55 idle temperature During gaming it went down from 97 to 73(max), What a relief
    ROG Guru: Green Belt Array mrwolf's Avatar
    Jun 2012
    21
    657
    Ah nice, good to hear it was just dust
    54-55 idle and 73max with full load is perfectly normal.. Enjoy the machinee do some overclockingg !
Tags for this Thread
