Results 1 to 4 of 4
12-22-2012 11:14 AM #1
- Join Date
- May 2012
- Reputation
- 10
- Posts
- 4
Xonar Phoebus settings won't save.
Hi!
For the most part I'm pretty happy with the phoebus but the one thing that still annoys the hell out of me is the fact that the Headphone Settings just flatout refuse to save.
I'm using 300ohm headphones so needless to say I'm in need of some power.
This is what i'm talking about btw:
Anyway,
Every time I reboot the computer this setting resets to "Normal Gain (0dB for <64ohm)"
Is there a way to set it to High Gain permanently?
Thanks for your time
12-22-2012 01:15 PM #2
- Join Date
- Jul 2012
- Reputation
- 33
- Posts
- 232
It will only save when you have updated to 3.08(CR). Not sure whether firmware 1015 that's included is required as well. Just thought I'd mention it, because quite a few users have had problems with updating the firmware.
12-22-2012 03:13 PM #3
- Join Date
- Nov 2012
- Reputation
- 10
- Posts
- 102
I believe it's a driver bug, fixed with 3.08(CR). Nothing to do with firmware.
12-22-2012 04:08 PM #4
- Join Date
- Jan 2011
- Reputation
- 20
- Posts
- 463
It was fixed with the latest driver. Download it and install the driver. If you need the firmware it will auto update it for you also. Thanks
