I´m new in this community and also new building a rig.
I wanted to play games and also overclock my system, but I have some issues with my ram.
First of all these are my system specs:
CPU: I7 3770k
Cooler: H100
Mobo: Maximus V Extreme
Ram: G.Skill Trident x 16GB 2400mhz (quad channel)
GPU: GTX 670 DCii
PSU: CM 1200w gold
So I installed the new drivers available for sound and gpu, updated bios with bios tool and installed bf3.
I began to play it and everything was fine, but suddenly after 5 -20 minutes it just crashed in video, sound still running and showed my desktop, but I was still in the game. The only way to get normal was opening task manager and close the process. I read about it and maybe was realtek drivers issue, I disabled the sound in bios, the same issue. Maybe stock overclock in the card, I underclocked it with gpu tweatk to normal mhz, nothing. So I read that maybe was faulty ram or something, the weird thing is that only in bf3 the system crash to desktop, BSOD or Directx error.
So I tried removing all the ram and test stick by stick, I tried all the sticks in different setups in dual channel but didnt worked, but works great with just 1 stick installed. I test every stick at time and no error with it. So my question is:
Is that a ram voltage issue or timmings are bad? As I said, this is my first rig. I just noticed that the model of the ram isnt in the QLV of MVE page (model F3-2400C10Q-16GTX) but the mobo was in the QVL of the RAM
http://www.gskill.com/products.php?index=512I tried running XMP profile #1 in the bios and set ram to 2400mhz at 1.65, also tried 1600mhz at 1.55v and 1.60v but the same problem with dual or quad channel.
Here´s the capture of directx error, also event viewer error code and paths that explain in the error and BSOD capture.
event viewer error code 1001 Windows Error Reporting
C:\Windows\LiveKernelReports\WATCHDOG\WD-20121226-2122.dmp
C:\Windows\Temp\WER-1375258-0.sysdata.xml
C:\Windows\Temp\WERFCC5.tmp.WERInternalMetadata.xml
files maybe are availble here
C:\ProgramData\Microsoft\Windows\WER\ReportQueue\Kernel_0_0_cab_02193a26
Hope someone can help me.
edit: also I forgot to mention that I will run memtest tonight and I´ll edit if there are errors.
Chassis: HAF X Nvidia Edition
PSU: Cooler Master Silent Pro Gold 1200w
CPU: Intel 3770k 4.2Ghz Vcore 1.104
RAM: 16GB GSkill Trident X 1866Mhz 1.5v (2400Mhz 1.65v)
Mobo: Asus Maximus V Extreme
GPU: Asus Gtx670 DirectCU
SSD: Corsair GT Force 240GB
Storage: Western Digital Caviar Black 1TB
Cooling: H100 Sandwich (4 Scythe Gentle Typhoon) Mx-4 Thermal Compound
http://valid.canardpc.com/2656704
