06-23-2011 04:04 PM - last edited on 03-05-2024 08:10 PM by ROGBot
06-24-2011 09:35 AM
06-27-2011 07:09 AM
06-27-2011 07:14 AM
icemanjs wrote:
anybody have any other info..i emailed asus and they told me to use the forums to find or get a answer and so far not happy that stuff on a $350 board doesnt work right
06-27-2011 07:59 AM
06-27-2011 08:22 AM
icemanjs wrote:
raja i have a mouse,keyboard,apc power backup and a linksys wireless adapter..os is windows 7 64bit and newest bios i believe..usbs are hard to tell starting up the top
top left isn't working
none on in the next area
then the on on the right
then the last ones work
i have tried the new drivers,changing stuff in the bios..right now what i have plugged in works but if i wana plug something that is plugged in already to a different usb then it doesn't work..its like they are fixed to that one usb
dont have the email anymore..i also tried facebook but they said all tech stuff to go here..i swapped out a rampage 3 board for this board and was told that i didnt have to reinstall windows or anything as it will still boot and such..other then the usb issue i have had no other issues
06-27-2011 08:42 AM
Raja@ASUS wrote:
Hi
I think it would be wise to reinstall Windows afresh if changing chipsets (my personal opinion). Some of the NEC drivers may only sit well with certain NEC firmware, so its usually wise to use the latest BIOS on the ASUS site together with the NEC drivers on the ASUS site also. When you change the device ports if you go to device manager and scan for hardware changes does anything at all show up? Can you list the make and model of the keyboard and mouse please?
-Raja
06-27-2011 10:55 AM
06-27-2011 11:41 AM
06-27-2011 08:27 AM
