ROG maximus IV extreme-z USB 3.0 Driver problem
Fax2u
Hello.
I have an ROG Maximus IV extreme-z MOBO (with the most updated bios version) and only 2 out of 8 +1 (On the front panel) are working...
It seems to be a driver problem.. But I deleted and installed the usb driver countless times with no success of fixing it...
It worked fine untill now.. I have no idea why ... Please Please help me
7 REPLIES 7
Jim-M4EZ
... post a screenshot of your Device Manager -> Universal serial bus controllers ...
What version of the Renesas/NEC USB 3.0 Controller drivers are you using ...
- M4EZ - 1: 3510 - 2: 1004 / i7-2600K / Redline 2133 16GB / Win7 Pro x64
- v.3510 / 8.0.0.1351 - v.8.1.0.1263 / 10.8.0.1303 - v.11.2.0.1006
- RevoDrive3x2 240GB - OS / Vector 256GB x2 RAID0 - OS / Vertex3 MI 120GB - OS / P'9230 3.0 2TB - B/U
- 9260-8i BBU - CacheCade Pro Vertex3 120GBx2 RAID0 SSD Caching - Const ES SAS RAID10 GHS - Data
- GTX580 3GB HC2 / Xonar Essence STX / ST1200G / TJ10B-W / ZR30w / SP 2500 2.1
- Water: Swiftech/Koolance/Tygon/EVGA/MIPS - Wind: SST/Noctua/Cougar
15578
And I downloaded the newest USB driver from the ASUS website
Jim-M4EZ
Well, both your Renesas USB 3.0 Controllers are showing ...
... you might try the latest Renesas USB 3.0 driver v.2.1.39.0 - found here : http://www.overclock.net/t/1042186/asus-z68-series-information-thread-drivers-bioses-overclocking-re...
Fax2u
I updated it and still it is the same problem.. Device manager looks the same
Jim-M4EZ
What Win OS are you running ... what bios version are you on ...
Those 2 Unknown Devices should be showing as Generic USB Hubs ...
... have you updated your Intel ME driver, or Intel Chipset driver lately ...
When's the last time you cleared cmos ...
Fax2u
I reinstalled windows 7 64bit lately
Latest bios
and I cant remember when I cleard my cmos
When I installed win7 again I downloaded all the drivers from asus
Fax2u
I fixed it! All it took is to clear Cmos
