Results 1 to 6 of 6
    ROG Member Array
    Jan 2013
    17
    17
    G75 with SSD and wireless card
    Hi guys, any advice is appreciated.
    Does anyone have experience about which SSD works well or badly with a G75 G75VW-DS71? My first time getting a SSD, shooting for about 128GB.
    Also for wifi cards, is the default card good enough or should I upgrade it? If so, any particular card to consider or avoid? (Wifi here is really busy and dies sometimes, I dunno if a better wireless card can help.) Thanks!!
    ROG Guru: Black Belt Array rewben PC Specs
    rewben PC Specs
    Laptop (Model)G55VW-3D
    MotherboardASROCK Z97 EXTREME 6
    ProcessorINTEL 4790K
    Memory (part number)G.SKILL RIPJAWZ 2400MHZ (F3-19200CL10Q-32GBZHD)
    Graphics Card #1ASUS STRIX-GTX980-DC2OC-4GD5
    Graphics Card #2ASUS STRIX-GTX980-DC2OC-4GD5
    MonitorDELL U2713HM
    Storage #1SAMSUNG SM843 480GB X2
    Storage #2WD GREEN 3TB X2
    CPU CoolerSWIFTECH H240-X
    CaseNZXT H440
    Power SupplyTHERMALTAKE TOUGHPOWER XT PLATINUM 1275W
    Keyboard CORSAIR K70 RGB
    Mouse STEELSERIES KINZU V3
    Headset STEELSERIES 9H
    Mouse Pad STEELSERIES QCK+
    Headset/Speakers LOGITECH Z506
    OS WINDOWS 10 PRO AU
    Network RouterASUS RT-AC66U
    Jun 2012
    178
    2,229
    1. there are many good ssds; my preferences are samsung 840 pro, intel 520, plextor m5p, crucial m4. get 240-256gb if possible (higher performance yields than 120-128gb)
    2. i am ok with the default wifi card (i use ethernet most of the times); but to many its performance are considered bad. the compatible ones with bluetooth that i know of are intel 6235 and bigfoot killer wireless-n 1202.
    edit: sorry i forgot; for wifi card, a better alternative is to use usb wireless dongle.
    New ROGer Array
    Oct 2012
    13
    2,441
    did you meet any problem or just want to upgrade device?
    ROG Member Array
    Jan 2013
    17
    17
    No problems, just upgrade Although the wifi connection could be better (again, not sure if it's related to the laptop or not).
    1. Yeah I really liked Samsung 840 Pro but I heard its TRIM isn't great. And you convinced me to get the 256GB.
    2. I admit I know nothing about laptop Bluetooth so I dunno if I ever use it. Why is wireless USB adapter better than a new wireless card? Which model do you use, or what's good/bad?
    One quick question, anyone know what the factory/default wifi card is in a G75VW-DS71?
    Thanks for the info guys!
    Recognized Troll Array
    Aug 2012
    21
    316
    If you want Bluetooth, Intel 6235, if not, Intel 6300 or check out Killer-N
    G75VW-DS73-3D | 670m 3GB | 32GB RAM | 1TB RAID-0 2 x 830 512GB SSD DualBoot | Killer-N 1103 WiFi
    ROG Member Array
    Jan 2013
    17
    17
    A super helpful thread: http://rog.asus.com/forum/showthread...drops-randomly
    Apparently G75 laptops have Atheros cards? Hmmm.
    I'll probably switch to the Intel 6235 you guys are talking about. But what's this I hear about the new Bluetooth possibly acting weird after installing the Intel?
Tags for this Thread
