Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 21
    ROG Enthusiast Array
    Jan 2013
    30
    Smile project [Leonidas Beard]
    "Tonight we dine in hell"©
    System:
    CPU: Intel i7 3930K
    MOBO: ASUS Rampage IV Extreme
    RAM: Corsair Dominator Platinum 4*4Gb
    SSD: Crucial M4 128Gb
    HDD: WD 3*2Tb
    VGA: 3*GTX 580 1,5Gb
    Sound Card: Creative X-FI Titanium HD
    PSU: Corsair AX1200
    CASE: CaseLabs M10 + Extended top + Pedestal
    _________________________________
    Water:
    Rad#1: TFC MONSTA Extreme
    Rad#2: TFC MONSTA Lite
    Rad#3: Alphacool nexxxos MONSTA
    Pump#1: DDC 1T
    + EK-DDC Dual TOP
    Pump#2: DDC 1T
    CPU block: EK HF Nickel Plexi
    VGA block: EK-FC580 GTX Acetal+EN
    FANS: Noiseblocker BlackSilentPRO 140mm, 1700rpm
    CONECTORS: Monsoon, EK, Bitspower
    LIQUID: Mayhems Blood Red
    CONTROL: Aquaero 5 PRO + 5 LT + PAU2
    I welcome you comrads! I write to you from the cold mother Russia :brrr:
    At once I ask me to forgive for my English, but I promise to try diligent
    The idea on creation of this project arose in me very long. Initially everything was planned to make with the Cooler Master Cosmos PURE case, but for a number of reasons, work was constantly postponed. And once I was lucky to take hold from CASE LABS, namely M10 in white color:clap: To it were bought in addition a pedestal and extended top
    Chief assistant always nearby
    Also the period of long thoughts at the choice of a project subject came. Options was much, but everything united them availability of blood, a large amount of blood:worried: So I came to a subject of droppers, tubes, and other hospital attributes, but what there was my disappointment when I casually came across one of the projects of the present most beloved by me, namely the White Silence project :waah:
    And again I fell into the abyss of thoughts...:grr:
    Then I was come to mind by idea to devote the project of Slavic mythology. At detailed studying of the weapon of Slavs, I started finding certain similarities to a cold weapon of ancient Sparta... and here upon me dawned...HERE IT, I exclaimed! IT IS SPARTAAAAA!!!
    Then received a clip from the beloved wife for shouts in the middle of the night
    Jan 2013
    30
    The history about 300 Spartans is one of my darlings, and how it was shown in Zack Snyder's movie of "300" adequately loud applause
    I several times revised the movie, finally like idea and started a choice of the most spectacular moments, for the purpose of sketch creation.
    And I came to 3 options:
    1.
    2.
    3.
    The third since there is more than dynamics and action was chosen.
    Well and because my friend is engaged in an aerographics I was allowed to his equipment and work began:
    In parallel with drawing, the lateral window was transferred to a laser engraving, here that appeared as a result:
    The photo in a subject will be more better a bit later...
    And again painting...
    Jan 2013
    30
    If very long not to leave the room it is possible to catch very qualitative hallucinations
    By the way, I decided to paint everything, a fitting's, water blocks, radiators, painted everything that to hand... the cat managed to evade
    In intervals between painting I entertained myself clothing of wires:
    Jan 2013
    30
    On fans stickers with the "300" logo were made:
    The hardware assumed to an upgrade:
    Jan 2013
    30
    And again case...
    With each portrayal the case starts coming to life, and it is all the second varnish coat
    I couldn't avoid a blood subject:
    Now I solve a problem of installation of tanks and I sew wires:
    By the way here the established lateral window so looks:
    All of happiness
    Jan 2013
    30
    It is a little new things. Normally to test it didn't turn out since DDR isn't compatible on height to CM V10
    Well and some samplers of a logo and holders of the tank:
  7. #7
    ROG AirWays Captain Array TenBlade's Avatar
    Oct 2012
    45
    815
    You´re a real artist, spasiba for sharing!
    Edit: Wow, 300 is just showing on TV3 now
  8. #8
    ROG Member Array
    Jan 2013
    5
    Wow that airbrush work is off the hook.
  9. #9
    Jan 2013
    30
    Thx guys, will be soon updatings, is now occupied with production of fastenings and placement of couple of Bitspower tanks
  10. #10
    Jan 2013
    30
    On days off continued to be engaged in production of holders. As the computer in the sorted condition should be drawn in the old manner. I will make some options, I will leave that will be pleasant more.
    As faced a small problem when fastening tanks, it is necessary to think how to connect them to the top radiator:
    They will be connected in parallel among themselves from above and from below by means of сristal-links:
Tags for this Thread
