Would these be ROG projects or personal projects you refer to? If it's non-ROG stuff then we don't even have a General discussion area, let alone a specific one for personal projects 🙂
That would be for ROG projects , say for example some utility program using ROG connect or some themes for ROG hardware. Although the latter would easily fall under "Modding".
Well to tell the truth i do have something but you can't call it "viewable" yet xexe :P, what im trying to make is to create a station where you can monitor and control several m/b using one ROG connect at once. The First limitation i came across was the source code , since i don't have it ill have to build the thing from the start which was a no-go. SO now im trying to create something to run several ROG connect apps from the same window something like virtualization off some sort.
I don't know if this is the right section but I do have a project I'm working on and would like an opinion... I'm creating a Windows Vista/7 Icon set and if this first image is good enough I'll continue with the theme so let me know?
It's a document icon, right? If I can recognize it then it must be a good design. I would skip the opacity on the cover since the icon has to scale. At smaller scales that will just look like noise. Otherwise I think you're on the right track.
Thank you for the advice...I just finished this set and uploaded it to http://daemoncantor.deviantart.com/#/d48cbs9 please take a look and tell me if I had done any better with the set...here when I've rested my little gray cell I'll start on more and hopefully get a whole set built...
This stuff is hard when all you do is frag things in a game!
