Page 1 of 2 1 2 LastLast
Results 1 to 10 of 12
    13kings
    Guest
    Problems with MKV video playback
    I am trying to run mkv files on my G74SX-3DE using vlc, media player classic, divx, and several other players. I've run quite a few mkv files already with no problem at all but all of a sudden I'm getting very choppy framerates whenever I try to watch them (probably around 20% of the normal speed with choppiness).
    Has this happened to anyone or does anyone know how to fix this.
    TeamROG Notebook Member Array Chastity@ASUS's Avatar
    Oct 2010
    18
    1,334
    There are so many things that can effect video playback that it's hard to troubleshoot the issue based on what you are telling us. When was the last time it worked properly, and what changed since then?
    Kicking Ass Since Today
    ROG Member Array
    Jul 2011
    9
    Have you downloaded codecs like CCCP? Try it. Here's the link: http://www.cccp-project.net/
    G73SW-3DE
    Intel Core i7-2630QM
    NVIDIA GTX 460M - 800/1500/1600 tested w/ 3DMark Vantage @ 73C(max)
    8GB DDR3-1333
    500GBx2 Seagate Momentus XT
    13kings
    Guest
    It was working a few days ago but I've been downloading alot of driver updates since the laptop's relatively new. I think one of the new drivers most like has something to do with the problem I'm having. However since e I've downloaded so many I'm not sure which of them could be causing the problem.
    @EdanRamz
    I just downloaded CCCP from your link but it didn't seem to fix the problem. I'm not too familiar with functions of video codecs so I downloaded and installed it with its default settings without changing much.
    Any idea about what I should do guys? I watch alot of video files in mkv format so I'm thinking that if I can't find a solution then I'll probably just to a clean reset of my OS and pay watch out for what might've caused the problem next time. But it'd be awesome if I could solve this without having to go that far.
    474
    Guest
    http://code.google.com/p/mulder/downloads/list
    http://mulder.brhack.net/
    Smplayer/mpui
    If you set it up right, you can have a 720p/1080p movie using between 3-7% processor usage in task manager
    careful though, install some of the older versions if a new one doesn't work right, he fixes and updates regularly.
    Always use the full package.
    I'll post later on how to set it up right when I have some time.
    13kings
    Guest
    Thanks for the link. I just tried smplayer but I'm having the same problem. It turns out that I'm actually having the same problem playing AVI files correctly. I don't think that it's a problem with the CPU or RAM but instead it might be an update that I downloaded.
    For some reason however, all the videos that I play using Windows media player run without a problem (it's actually the only player that works without problems. This would be fine but WMP doesn't handle certain video types very well such as MKVs.
    Has anyone heard of this rare issue or know why WMP is the only player that is able to run videos correctly?
  7. #7
    TeamROG Moderator Array xeromist PC Specs
    xeromist PC Specs
    Laptop (Model)Dell Inspiron 15 7567
    MotherboardMSI x470 Gaming Plus
    ProcessorAMD 2600X
    Memory (part number)16GB Crucial Ballistix Elite 3600
    Graphics Card #1ASUS GTX 1080 Strix
    MonitorBenQ BL3200PT
    Storage #1Intel 600p NVMe
    CPU CoolerWraith
    Casecustom Antec 900
    Power SupplyCorsair HX1000
    Keyboard Logitech Orion Spark
    Mouse Logitech MX500
    Headset Plantronics 777 with Oregon Aero upgrade
    xeromist's Avatar
    Jul 2010
    294
    7,381
    Have you compared CPU usage when running WMP and one of the other players?
    * Support disease research with Folding@Home *
    < < < Click the drop-down above my avatar for my PC specs!
  8. #8
    474
    Guest
    General>Video> output driver | DirectX Fast - Double Buffering, Draw Slices
    Performance> Disable the loop filter | under Cache 12,xxx 40,xxx or 99,xxx [cache settings that worked best under different builds]
    Advanced> Colorkey, can be fun if you turn your interface all one color under windows classic, you still get 3-7% Processor Usage
    If you go nuts on a 1080 file and fast forward holding down the arrow keys, the cpu pegs @ 26, 37, 56% depending on how it was encoded.
  9. #9
    Oct 2010
    18
    1,334
    Just as a test, I would uninstall any codec packs, and then install the current MPC-HC, and let it use it's own internal codecs. See if this fixes the issue.
  10. #10
    474
    Guest
    print screen button, save it in paint.
    ctrl+Shift+esc key to get to task manager, right after start up
    then another screen shot right after the media player is open and running
    Do you have a stock backup of the way it came out of the box? "Windows Backup"
    Even if you don't have that I'd make one right now (external drive) and reinstall the factory state, https://addons.mozilla.org/en-US/firefox/addon/febe/ to backup your browser
    Another back up of the fresh reinstall, open the windowsimagebackup folder, tell it yes you want to gain access, new folder one directory abov it, send the backup folder to the new folder you just made, that way you can shuffle your backups
    Oh yeah, www.videohelp.com for all your video needs, that and http://forum.doom9.org
Similar Threads
  1. Ran into a few problems :)
    By TheDeepFryer in forum G Series Gaming Notebooks
    Last Post: 07-01-2011, 01:39 AM
  2. Problems with new build
    By jlewis02 in forum Other Series Motherboards
    Last Post: 03-19-2011, 02:25 PM
  3. G73jw-3de CinePlayer / 3D playback issue
    By Pierre2k in forum G Series Gaming Notebooks
    Last Post: 02-04-2011, 01:16 PM
  4. XMP problems
    By c3cris in forum Other Series Motherboards
    Last Post: 01-28-2011, 04:58 PM
  5. G73 Blu-ray drive problems
    By wingdam in forum G Series Gaming Notebooks
    Last Post: 01-10-2011, 11:15 AM
Tags for this Thread
