Page 1 of 4 1 2 3 ... LastLast
Results 1 to 10 of 37
    ROG Member Array
    May 2012
    13
    G75 VW Memory Speed and Upgrade
    Hello everyone,
    I just upgraded my G75 VW to Windows 8 and now I wanto to add more memory, at the moment has 16GB but I wanted to upgrade to 32GB, can I do that, does the laptop support 32GB memory (I know that the CPU does, but what about the board...)?
    Besides that I decided to run CPU-Z and appears that the memory is not running at 1600mhz as I though that would be, but at 800 MHz, what's going wrong here?
    I'm including the CPU-Z report for anyone that could look at it and help me with this.
    Back to the beginning, this laptop support 32GB? What memory do you recommend (FAST FAST Memory has the laptop can handle) - please post a link Amazon or something similar (with prices ).
    Thank you for your help.
    ROG Guru: Brown Belt Array GottiBoi55's Avatar
    Dec 2011
    22
    1,117
    Quote Originally Posted by JMSPT View Post
    Hello everyone,
    You are getting 800 MHz (edit: DDR dual channel memory) will 'bench" that way!
    So 800 MHz times two
    (edit: with DDR dual channel memory) = 1600 MHz.
    Edit: Sorry my bad, I meant DDR dual channel memory.
    You should be good to go with 32GB, just make sure you get the correct timing CL11 (11,11,11,28)
    But keep in mind, there's two memory slots that's not user accessible, you will void the warranty to access them!
    PS: Oh BTW, Win8 (64Bit) supports up to 128GB of memory, and Win 8 Pro(64 Bit) 512GB!>>>>Source
    GottiBoi55
    Asus
    G750JZ-DS71 Windows 10 Pro (x64)
    Intel® Core™ i7 4700HQ (2.40GHz)
    Samsung
    24GB Memory DDR3 1600 MHz SDRAM
    SanDisk
    M.2 SSD 2x128GB in Raid 0 / WD-HGST-1TB HDD 7500-RPM
    NVIDIA® GeForce® GTX 880M 4 GB GDDR5 VRAM
    Second Monitor: Shar
    p Aquos 32"
    New ROGer Array
    Oct 2012
    13
    2,441
    i suggest you follow the spec from ASUS support site, that would be getting best performance and stability.
    ROG Member Array
    May 2012
    13
    ok, thank you for the resposnses.
    How can I access the hidden memory slots (do you have a link to a tutorial)?
    "i suggest you follow the spec from ASUS support site, that would be getting best performance and stability."
    Can you post the link?
    New ROGer Array Zygomorphic's Avatar
    Mar 2012
    176
    4,761
    Question: How many slots does CPU-Z say are occupied? If only two, then the hidden slots are usually the ones occupied, and you can just take the back of the notebook off and add 16 GB of RAM (following @GottiBoi55's constraints on timing) without a problem. Otherwise, it is a serious disassembly job.
    I am disturbed because I cannot break my system...found out there were others trying to cope! We have a support group on here, if your system will not break, please join!
    http://rog.asus.com/forum/group.php?groupid=16
    We now have 178 people whose systems will not break! Yippee!
    LINUX Users, we have a group!
    http://rog.asus.com/forum/group.php?groupid=23
    ROG Member Array
    May 2012
    13
    unfortunately, all 4 slots are occupied...
    - Is it so difficult to add 4 memory cards (8GB each)? Any tutorials on that?
    - If I saw some tutorial about that I could decide if I can handle that job, if not, I was thinking about removing 2 of the memory cards (from the visible slots) AND add 2 with 8GB each - then I would end with 8+8+4+4 = 24GB - (in this case what precautions should I need to consider - I'm thinking about memory compatibility with the existing ones ).
    Thank you
  7. #7
    ROG Guru: Orange Belt Array
    Jan 2013
    18
    313
    Quote Originally Posted by GottiBoi55 View Post
    [COLOR=#ffffff]You are getting 800 MHz per channel, Dual channel will 'bench" that way!
    So 800 MHz times two channels = 1600 MHz.
    Er... That's not because of dual-channel, 800mhz = 1600mhz because it is "double data rate".
  8. #8
    ROG Guru: Black Belt Array rewben PC Specs
    rewben PC Specs
    Laptop (Model)G55VW-3D
    MotherboardASROCK Z97 EXTREME 6
    ProcessorINTEL 4790K
    Memory (part number)G.SKILL RIPJAWZ 2400MHZ (F3-19200CL10Q-32GBZHD)
    Graphics Card #1ASUS STRIX-GTX980-DC2OC-4GD5
    Graphics Card #2ASUS STRIX-GTX980-DC2OC-4GD5
    MonitorDELL U2713HM
    Storage #1SAMSUNG SM843 480GB X2
    Storage #2WD GREEN 3TB X2
    CPU CoolerSWIFTECH H240-X
    CaseNZXT H440
    Power SupplyTHERMALTAKE TOUGHPOWER XT PLATINUM 1275W
    Keyboard CORSAIR K70 RGB
    Mouse STEELSERIES KINZU V3
    Headset STEELSERIES 9H
    Mouse Pad STEELSERIES QCK+
    Headset/Speakers LOGITECH Z506
    OS WINDOWS 10 PRO AU
    Network RouterASUS RT-AC66U
    Jun 2012
    178
    2,229
    Thank you
    - it's not hard, just tedious; here's the teardown; but i think you can stop at the point where you can access the hidden ram slots.
    - you can check here for steps that you need to know if you do not touch the hidden slots (keeping the stock ram).
    i used to run 2x8gb kingston ram along with stock ram.
  9. #9
    ROG Member Array
    May 2012
    13
    Ok, thank you for the answers.
    One final question, I also have a G75 VX model (bought a couple a days ago).
    I noitice that I don't have the software to do the disk image to DVD's nor Windows8 serial key.
    I was planning to do the disk image (after I do the BIOS updates, driver uptes etc...), what software should I use to perform the installation images? And Why this new laptopt does not have windows 8 serial key?
  10. #10
    rewben PC Specs
    MonitorDELL U2713HM
    CaseNZXT H440
    Jun 2012
    178
    2,229
    you can use macrium reflect or windows file backup in control panel to create the recovery image. to get the w8 key, use keyfinder. your w8 key now is embedded into bios, so there is no w8 serial key sticker anymore.
