Air Flow aand Tempreatures
Retired
Not applicable
Been gaming and just taken a look at the air flow at the back of the laptop (g73), on the right vent (looking towards the monitor) im getting good airflow, lots a hot air coming out :), while in the left i don't seem to be getting any, is this normal?
I'd also like to know which vent is for which component (cpu or gpu) and also, what are the safe operating temps for both as well.
Any help will be appreciated.
jorlanm
The left vent is for the CPU...the right is for the GPU...the Gpu tends to run hotter even on idle so you will get more venting out of the right side...temps intel says the i7 can go up to 100c before you run into problems...the GPU nVidia claims that 460m can run on 105c and still stable, but never specified the max...
-ASUS ROG G73SW-3DE-
-Intel Core i7-2630QM Mobile Quad Processor
-Intel HM65 Express Chipset +ICH10
-17.3" 1920x1080 120Hz Anti-Glare Matte Screen
-nVidia GeForce GTX 460m 1.5GB GDDR5 VRAM
-nVidia 3D Vision Active Shutter Glasses
-Creative EAX Advanced HD 5.0
-THX TruStudio
-8GB DDR3 1333MHz RAM (Max 32GB)
-2x500 Seagate Momentous XT Hybrid HDD
-Blu-Ray 4x Burner
-Logitech Performance MX Darkfield Laser Mice
-Microsoft Windows 7 Ultimate
-XBOX360, PS3, Wii
Chastity
Sounds normal, as each fan is dedicated to one component, and is regulated independently.
[SIGPIC]Kicking Ass Since Today[/SIGPIC]
On idle my cpu temPs are 38~42c gpu is at 58~62c
Load cpu is 59~61c gpu is at 74~79c
-THX TruStudio
-Blu-Ray 4x Burner
-XBOX360, PS3, Wii
