iI have the touchpad software set to disable the touchpad when ever a USB mouse is plugged in (which is always for me) and after every reboot I have to go in and uncheck the option, hit apply then check the option again and hit apply to get the touchpad to disable.
The touchpad software says Sentelic Version 9.1.3.5 I went to the sentelic website thinking maybe they've got an update to the software/drivers that would fix this but failed to find anything for the end consumer on their website.
Any insight into this problem would be appreciated.
Thanks
