eXtreme trooper 5Ghz project
sstephan
the purpose of this project was to run at 5Ghz 24/7 stable at all costs lol .
the board ...
the cpu
case...
32 REPLIES 32
sstephan
lots of ram too...
and some watercooling parts ...
Retired
Not applicable
Nice, keep em coming
testing the 1155 socket pin compression distance ...
socket open , gauge reset
socket closed
there will be blood
this is not the last time this cpu will suffer . this is only the beginning
the socket will suffer too
will continue later
chrsplmr
Level 18
Oh ... ROG yes !!! .. Im gett'n some pop'corn ..
McBonerFart
I wish you luck,
I'm not sure what to type here
I will be watching this with interest as I am looking to get as close to 5ghz under water, it would be interesting the results as your using xspc and swiftech and I am using all koolance for the cpu and the ek block for the motherboard.
KPRage
Awesome.. Keep it coming.. Nice start.. 🙂
CPU: Intel i5 3570k OC'd to 4.6GHz @1.170V; Mobo: MVG; GPU: Zotac 1070 mini OC'd to +210MHz/+205MHz; Memory: 8GB (2X4GB dual channel) Corsair Vengeance 1333Mhz 9-10-9-T2; SSD: Samsung 840 pro; HDD: 1TB WD Green 6Gbps; PSU: Corsair GS 600w; Case: Bitfenix Merc Alpha:Hybrid Octane in progress; Cooler: Corsair H80 closed loop cooling @ high profile;
Pre & Post Build Guide
A lot of epic FAIL videos are made before one epic WIN video is made 🙂
