I recently built my first PC, but have been having a little (or a lot) of trouble with it. When i first turned it on, it started running, inciting cheers from my brother and I. At first it was low on voltage, so we turned it off and plugged in a few optional power cables into the case. When we turned on the computer next, we got into BIOS. We again turned of the computer, to finish up some cable management.
Upon turning on the computer again, however, the computer started got into a cycle that has started every time the computer is turned on:
1. The computer goes through POST.
2. The computer makes a single sharp bleep.
3. The screen comes up with the following message:
Asmedia 106X SATA Controller Ver 0.93 AHCI Mode
S.M.A.R.T. Supported
Using PCIE Gen 2
and after a couple seconds the line "Can't find any device." is added to the bottom.
Using PCIE Gen 2
4. The screen goes blank for a few seconds, then shows up with:
Updating iROG firmware now. DO NOT reboot or turn off computer.
after a few seconds, that becomes:
Update firmware successfully.
5. The imput to the screen stops, and the cycle is started over with POST, lasting indefinitely.
Throughout this process the Boot device LED remains on (after the first POST). Unfortunately, everywhere I've looked everything done a lousy job of explaining what this means (and what the boot device actually is; i would assume its the hard drive or a disk with the OS.) If it helps, the first bleep coincides with the boot device LED turning on, so I'm not sure if the bleep is just something that happens when something wrong is detected during POST, or it means only what it said in the manual (basically that my keyboard is incompatible). Either would make sense, since i can't get my keyboard to do anything throughout the process.
If anyone has any idea what to do, I'd appreciate the help. If you need more information to help me, I'd be glad to give it to you. Thanks 🙂
EDIT: I Discovered That i can play the disk that came with the mobo during step three, but only during that step (so i have to close the disk drive at just the right time). Even then, it goes right back to step 4 after a second or two.
