Results 1 to 3 of 3
    ROG Enthusiast Array
    Sep 2011
    13
    62
    GPU Tweak Monitor Issue
    GPU Tweak Monitor only shows the primary card. If i select the secondary card, it's reporting nothing, it's blank.
    This is with 2x 7970 Matrix Platinum is crossfire and i've updated from 2.2.9.9 to 2.3.5.0 but to no avail.
    Any ideas?
    ROG Guru: Diamond Belt Array Zka17's Avatar
    Mar 2012
    183
    8,306
    Hm... was it working before? The GPU-Z part is showing things correctly?
    Sep 2011
    13
    62
    GPUz shows both cards, crossfire is enabled. I've only just got the second card and haven't been able to monitor it with GPU Tweak.
