06-25-2010 11:40 AM - last edited 3 weeks ago by ROGBot
I was recently talking to Cooler Master about a review on this cooler due soon. Cooler Master introduced the V6GT, a new high-end cooler with a nickel-plated copper base, six 6mm heatpipes and a large aluminium fin array that is cooled by two 120mm DynaLoop bearing PWM fans that deliver between 34.02CFM and 93.74CFM at a noise level of 15dBA to 38dBA.
The Cooler Master V6GT combines a new thinking in CPU cooler design, yet doesn’t compromise on cooling performance. It also packs a range of great features as standard, such as the use of a Double-V heatpipe design, twin 120mm DynaLoopTM PWM fans, a built in LED strip on the top and of course support for multiple CPU sockets.
Cooler Master has designed the V6GT as a no compromise air cooler and has come up with several new key improvements that makes this one of the best CPU air coolers on the market. Cooler Master put V6GT coolers through torture tests by using them to cool a pair Xeon X5670 processors on EVGA’s Classified SR-2 motherboard and a i5 655K processor.
The Xeon X5670 processors were overclocked to 4GHz, yet the V6GTs kept both CPU’s at sub 70 degrees C, and the i5 655K was overclocked to a mssive 5.269GHz under 66 degrees C, even during extended periods of extreme benchmarking at these high clock speeds.
By adding 55 densely stacked fins asymmetrically with a five degree tilt the V6GT has lower airflow resistance than your average heatpipe based cooler. This means that more air can be pushed through by the twin 120mm fans which results in vastly improved heat dissipation. The twin V shaped heatpipe layout maximizes the contact area between the 6mm heatpipes and the heatsinks, as well as putting all of the heatpipes in a direct path of the airflow.
The fans used on the V6GT uses a new type of bearings known as DynaLoop™ which extends the life of the bearings to 40,000hrs. The new wave shaped fan blades increases the airflow while maintaining an even air pressure which leads to less fan noise. Both fans also features PWM fan control which further helps reduce the noise from the fans when the CPU is idle or under a low load. The fans are also easy to install and remove thanks to a new tool-free snap-on fan cover. The fans operate at between 800 and 2200rpm and produce an airflow of 34 to 94 CFM per fan, yet the noise level is only a mere 15 to 38dBA.
The V6GT comes with a mounting kit that allows you to install it on all current CPU platforms. It’s supplied with all the mounting brackets, back plates and screws that you’d need, as well as a syringe of Cooler Master’s thermal paste. This means that there’s no need to buy any additional accessories to install the V6GT unlike some competitive solutions.
06-25-2010 02:20 PM
03-30-2012 06:58 AM
