ASUS G75VW BBK5 Running At 50C temperature on idle.
bbatod
Hello,
My my ASUS G75VW BBK5 is running at 50 Celsius temperature on idle.
18495
Is this normal? Should I clean out the fan?
When I checked this review http://www.notebookcheck.net/Update-Review-Asus-G75VW-T1040V-Notebook.76032.0.html
It says that it runs around 28C on idle. Is there something wrong with mine or does it just need some cleaning?
10 REPLIES 10
bignazpwns
Level 11
idle temps are useless whats your load temps like?
bbatod
doesn't increase in temp on idle mean that there is something fishy going on? hehe just my thought. I haven't looked my load temp. I'll check.
bignazpwns
Level 11
I would also use core temp to check the temps.
Apexing
no need to make two topics about the same thing.
you are also lacking a **** load of info for us to guess if the temp is normal.
what is the ambiant temp, what kind of surface is the laptop on, how long has it been idling, is fan filers cleaned, is it overclocked.
bbatod
Oh... the other one was not showing up. Sorry.
Ambient Temp: room temp 21C
Surface: Table
Idle Time: more than 1 hour
Filters cleaned: I cleaned one and left the other one because I got lazy.
Overclocked: No
bignazpwns
Level 11
still aint post those load temps yey. Or checked with core temp.
bbatod
This is what is showing on core temp.
Load temp is around 65C.
bignazpwns
Level 11
Is that a prime load? Dose core temp report thee same idle temp? If your loaf temp is only 15c higher that's fine
Pitcher1
have it make you laptop get problem, i think it is normal temp.
