03-28-201305:28 AM - last edited on 03-06-202409:37 PM by ROGBot
guys where can i find the 3 pin thinkgs that you connect the fans on the mobo?? i will make a external LED hub and i need some of these both males and females..here are some pics of what i wanna make...and what i need cause i cant find it at local shops...
Project Name: System Specs: Motherboard: Asus Rampage IV Black Edition Prossesor: Intel Core i7 4820k Graphic Card: Asus GTX Titan x2 *Power Supply: Cooler Master V850 Ram: 32Gb Corsair Dominator Platinum 2133Mhz Case: Corsair Obsidian 750D SSD: 2x Samsung Evo 250Gb Raid 0 HDD: 2x Seagate Baraccuda 2TB
Classic case of not reading. lol that 4th pin is going to be variable mhz siqnal for speed variation on your fans. Im not sure what you would need to split the signal successfully, but in theory you would only need to split that wire. Let me know how that works out.
**i7 3770k @ 4.5GHz~ Cooler Master V8 ~ Asus Maximus V Formula ~ G Skill Sniper Gaming Series 16GB DDR3-1600 ~ Thermaltake Black Widow 850W 80+ Bronze ~ Kingston HyperX 3K 120G SSD ~ 2x WD Caviar Black 1TB
~ WD 500GB ~ 2x ASUS GeForce GTX 660 Ti TOP 2GB ~ Philips 1080p 39"**
