04-04-2013 06:44 PM - last edited on 03-06-2024 09:29 PM by ROGBot
04-05-2013 03:58 AM
04-06-2013 08:56 PM
Mankz wrote:
^^ Yeah, why not something dedicated like a Aquaero 5?
http://www.bit-tech.net/hardware/2011/10/06/aquacomputer-aquaero-5-xt-review/
04-05-2013 04:02 AM
04-06-2013 04:21 AM
Arne Saknussemm wrote:
Having read over what you wrote i can't see anything glaringly wrong. Yes the 1A rating is for each header so probably best to run 2 fans off each one....maybe you would get away with three. you have to remember that at start up the fan draws a lot more for a split second before it gets up and running and then the voltage specified is true.
The power control of the fans is a bit crude on these boards and some fans relate better than others to this kind of control. As Zka17 suggests much better if you want full fan control is a fan controller mediating the power from molex....
04-06-2013 06:36 AM
Mithos wrote:
What benefits would one achieve through a dedicated hardware fan controller over what I assume is capable of with PWM/BIOS/FanXpert on my Maximus V Forumula?
04-06-2013 06:52 PM
04-07-2013 06:22 AM
04-07-2013 11:44 AM
