Results 1 to 6 of 6
    New ROGer Array
    Apr 2013
    3
    Maximus V Formula mPCI-E Wifi Card Help
    Hello!
    Thank you for your help in advance!
    I have bought this board, and obviously it came with the included mPCI-E wireless card and the antennas.
    MY question is... how do you attach it to the card? Is it to be soldered? Or was it suppose to come pre-attached... cause mine didn't. =(
    Sorry for the noob question. I tried to Google around but everyone's problem with it seems to be more compatibility instead of the actual attachment.
    Thank you!
    ROG Guru: Grand Master Array
    Oct 2012
    339
    15,255
    Welcome to the ROG forums, KrazyKat.
    Installing the mPCIe card is actually very easy.
    1. Remove the two screws from the mPCIe card.
    2. Line up the module and insert it in a angle.
    3. Hold down the module and put the two screws back in.
    4. Flip the mPCIe card to it's side and remove the screw from the metal bracket.
    5. Look on the top left side of your motherboard to find the mPCIe connector. Insert the mPCIe card into this connector.
    6. Flip your motherboard over and put in the screw you removed earlier from the metal bracket to secure the card in place.
    7. Grab the antenna cables and connect the two connectors to the two pins on the mPCIe card.
    7. Remove the two bolts from the Wifi antennas.
    8. Continue to install your motherboard into the case.
    9. Insert the two connectors through the I/O shield's two holes and re-attach the two bolts.
    10. Screw in the two antennas and you're done.
    ROG Enthusiast Array MultiDoc PC Specs
    MultiDoc PC Specs
    MotherboardASUS Strix Z370-I
    ProcessorIntel i7 8700K
    Memory (part number)Corsair CMK32GX4M2C3000C16
    Graphics Card #1ASUS Strix 1080Ti OC
    MonitorASUS ROG Swift PG279Q
    Storage #1Samsung 960 Pro M.2 NVMe 1TB
    Storage #2Samsung 860 Evo 2TB
    CPU CoolerNoctua NH-D9L (2xNF-B9 Redux PWM)
    CaseNcase M1 v5
    Power SupplyCorsair SF600
    Keyboard Wooting One Premium
    Mouse Logitech G703
    Headset Fnatic Duel TMA-2
    Mouse Pad OcUK 3XL extended
    Headset/Speakers BOSE Companion 2 Series III
    OS Windows 10 x64
    Network RouterNetGear R7000
    Accessory #1 Logitech C920 HD Pro Webcam
    Accessory #2 Glorious PC Gaming Race TKL keyboard wrist rest
    Accessory #3 ASUS USB-BT400
    MultiDoc's Avatar
    Mar 2013
    74
    Lightbulb
    Here's a pic of mine, hope it helps you get the idea of how to install it (don't have a better one at the moment):
    Cheers,
    Nick
    Asus Strix Z370-I (BIOS: 0612), i7 8700K (de&re-lided, Noctua NH-D9L 3xNF-B9 redux), Corsair LPX 2x16GB @ 3000MHz, Samsung 960 Pro 1BT M.2 + Samsung 860 Evo 2TB, Asus Strix 1080Ti OC, Asus ROG Swift PG279Q, Ncase M1 v5 (2xNF-A12x25 pwm), Corsair SF600, Logitech G703, Wooting One, Edifier R1700BT Speakers, Fnatic Duel TMA-2, Logitech C920 HD Pro, Win 10 Pro x64
    New ROGer Array
    Apr 2013
    3
    Thanks for the prompt responses... but more specifically - how do you connect the wires to the card?
    Oct 2012
    339
    15,255
    You see the two gold pins on the mPCIe card? You just connect the two antennas to it. Just put the connector over the pin and push down on it. It'll snap into place and you'll hear a click sound. There's no need for soldering.
    New ROGer Array
    Apr 2013
    3
    Oh my.... =____________="""
    Thank you sir.
Tags for this Thread
