Hello to you all!
Proudly presenting project “Bird of Prey”. It has taken me a long while to think it all through, carefully plan en go toward the actual build. I finally have completed the planning, the designing and I have obtained all the parts that I selected.
A big thanks to Aquatuning for supporting me! From today on I will share all that lies ahead in this build.
IntroWhat is it about you will probably wonder by now, uhmm, I am not sure where to start.
A few months ago I bought me a nice set of components, threw it in a case and started benching with. I joined the ROG OC supreme team, I like it a lot. Link to hwbot; http://hwbot.org/user/henkenator68nl/
But being able to obtain competitive scores takes a bit more than just a case full of good stuff –but nonetheless- the system performed nicely. Considering that it runs on stock air coolers.
So I wanted to upgrade it and put it under water… Easier said than done. The bucks, the time and the plan it took me a while but I am there now. I wanted to create a system that was not only able to do nicely in the Enthusiast league, but also was pleasing for the eye.
I came up whit this idea:
- Give it a truly unique look
- Collect a nice water cool set to get higher overclock possibilities
For the look I was inspired by 2 things, the first: a visit to “la sagrada familia”, a huge cathedral in Barcelona, Spain. Which is actually still in the process of being built. Before you run of … this has no connection to religion, simply something that I really loved: the stained glass windows. The effect of the sunlight on these windows is really beautiful, The colors are so bright, it almost looks like it comes to life.
The second thing that inspired me is this: Whenever I am outside and see a bird of prey flying through the skies, I really admire the animal. It flies patiently … until it spots a meal. It drops down and with unbelievable accuracy it just grabs his prey, like its nothing.
So I thought it would be cool if bird of prey would meet stained glass. After a lot of tweaking and fine tuning a made a design for a custom glass window to fit my case. And that is where the bird and the stained glass come together !!
I made a very colorful stained glass edge and an image of the bird of prey also in a stained glass version. Adding led RGB lights to the mix will surely give the case the same vibrant color as the stained glass I mentioned before.Take a look at the print I made:So how to get that ? That was not easy at all… but more about this later on.
All the components together are going to turn this build into a rather high-end system.
Up until now I have been running the following component’s in a Cooler Master Storm Stryker Case:
Current system
Motherboard : Asus ROG Maximus 5 Extreme
CPU : Intel Core i7 3770K (with a cheap Scythe Katana 4 cooler)
RAM : Corsair Dominator Platinum 2x4Gb, 2133MHz, cl 9
First GPU : Asus GTX 660 direct cu.
About 6 weeks ago I swapped the gtx660 for a HD7970 (the poor ******* needed money, haha but now I have that card).
Current GPU : Sapphire HD7970 GHz edition (after bios flash), 3Gb DDR5
PSU : Xilence 1000Watt modular
Drives: : SSD for booting and a HDD for data combined with a msata-SSD.
It currently looks like this:Nothing special at all, but serious potential!
So I went looking for some good stuff, there is almost too much to choose from (and unfortunately not enough money), but I succeeded . I got the following additional hardware:
New Water Cooling Set:
08. CPU block: Alphacool CPU block NexXxoS XP³
09. GPU block: Alphacool NexXxoS ATXP ATI 7970/50 series - polished stainless steel – black
10. Radiator1: Alphacool NexXxoS Monsta 240
11. Radiator2:Black Ice GT Xtreme 120
12. Pump: Laing DDC-pump 12V DDC-1T
13. Pump-box: Alphacool Laing DDC-SilentBox
14. Pump top: Alphacool Laing DDC Plexi cover
15. Reservoir: Phobya Balancer 150 black nickel
16. Fans: Noctua NF-F12 PWM ( 120x120x25mm )
17. Inline temp sensor: Phobya G¼
18. Fittings black nickel:
* 13/10mm (10x1,5mm) compression fitting 45° rot outer thread 1/4
* 13/10mm (10x1,5mm) compression fitting outer thread ¼
* 13/10mm stop
19. Tubing: Alphacool tubing AlphaTube HF 13/10 (3/8"ID)
Al this is available at the aquatuning shop.
Case Mod Products:
20. Phobya Sleeve kit UV-Blue
21. Revoltec rgb Led kit
22. Chill-r Custom unique glass window with designed Print
I have thought about this over and over and I think it is do-able.
I made a drawing to get a grip on the cool loop, the airflow etc.
Check it out:Water Cooling / airflow setupSo what do you think? Will it fit? Is this the best way to fit it all in and get the best results?
Here are a bunch of pictures off all the stuff I got in. So I started ripping the whole thing apart….Now the fun part begins … if al goes to plan, and believe Mr Murphy never ever misses my house on his route… continued in the next post..
