Results 1 to 9 of 9
    ROG Member Array
    Apr 2013
    5
    First Pc Gaming ,Help please (:
    Hey
    i want to buy my first pc gaming soon , and i need some help to grab the best build. my budget around $2,055.
    (i need a network wireless card/pen)
    leave ur build , to help me , thanks
    ROG Guru: Grand Master Array
    Oct 2012
    339
    15,247
    Hey there, my friend. Please fill this form and we'll start.
    Budget:
    Main uses of intended build:
    Parts required:
    Previous build information (list details of parts):
    Monitor resolution:
    Storage requirements:
    Will you be overclocking: yes/no (delete as required)
    Any motherboard requirements (no. of USB, Xfire/SLI, fan headers):
    Extra information about desired system:
    ROG Member Array
    Apr 2013
    5
    Budget: around $2,055.
    Main uses of intended build: Pc Gaming , to play the most recent games and upcoming games ( as , Battlefield 4 , Gta V , etc ... with maxed out settings)
    Parts required: ( cpu , gpu , motherboard , psu , ram , hdd + ssd , drive dvd , case , monitor and network wireless card/pen )
    Previous build information (list details of parts): nothing , my first desktop
    Monitor resolution: 1920x1080
    Storage requirements: already said , hdd (1tb) and ssd (128gb)
    Any motherboard requirements (no. of USB, Xfire/SLI, fan headers): not plan sli/xfire
    Extra information about desired system: i like this cpu , i think is good ( i5-3570K )
    ROG Guru: Diamond Belt Array Zka17's Avatar
    Mar 2012
    199
    8,358
    I haven't actually calculated (don't know where you're located), but something like this should get you go:
    Mobo: Asus Maximus V Formula
    CPU: Intel Core i7-3570k
    RAM: GSkill Trident X 2x4GB - you can easily go up to 2400MHz, but actually 1600MHz would be enough...
    SSD: 128GB Samsung 830 or 840 series
    HDD: Western Digital Caviar Black 1-2TB
    VGA: essentially a stock (not OC'd) AMD Radeon HD7970 or Nvidia GTX680 should be enough, but HD7950 or HD670 should do it too
    PSU: Seasonic X series, Corsair AX series - 750-800W should be plenty (it may look a lot of power, but I like to oversize my PSUs)
    Check these where you live/where you would buy and see how much is left...
    ROG Enthusiast Array
    Feb 2013
    11
    44
    Powerful, sensible, quiet, and understated ...
    $220 - Intel i5-3570K
    $200 - ASUS Maximus V Gene mATX
    $500 - EVGA GeForce GTX 680
    $110 - 16GB Crucial CT2KIT102464BA1339
    $100 - Fractal Design Define Mini mATX
    $200 - Crucial M4 256GB SSD
    $90 - Corsair 650TX
    $1,420 USD
    i5-3570k | V Gene | HD 4000 | Crucial M4 256GB | Fractal Design Mini | NEC 2490WUXi2
    ROG Guru: Orange Belt Array WeRNothiNg's Avatar
    Mar 2013
    31
    379
    That sounds like a winner, although I stay clear of mATX mobos for 2 reasons. 1- i like having plenty of room for airflow and my hands...lol 2-2 mATX have been known to run hotter. I kinda wish I would've gotten a GTX 680, not for performance reasons though. The 660 Ti has never let me down and I Ultra Everything! I would go with the Asus model no matter what you get. I also went with the Kingston Hyperx 3K ssd. go to anandtech.com and look at the benchmarks. They are neck and neck so get which ever is on sale. Read up on everything man. You can look at my specs in my sig, it is almost identical to the rigs listed above and it is a beast.
    I also have guides for all sorts of things once oyu install windows. So if you want pm me and we will optimize the hell out of Windows. There are also some things that must be done to windows or it will severely shorten the lifespan of you ssd.
    **i7 3770k @ 4.5GHz~ Cooler Master V8 ~ Asus Maximus V Formula ~ G Skill Sniper Gaming Series 16GB DDR3-1600 ~ Thermaltake Black Widow 850W 80+ Bronze ~ Kingston HyperX 3K 120G SSD ~ 2x WD Caviar Black 1TB
    ~ WD 500GB ~ 2x ASUS GeForce GTX 660 Ti TOP 2GB ~ Philips 1080p 39"**
    [IMG][/IMG]
  7. #7
    iron man Array kkn's Avatar
    Aug 2011
    243
    6,129
    1 ssd for OS, 1 ssd for games, 1 HDD for file storage/large programs, m5f, i5 3570K
    8 -> 16gig of ram from 1866 to 2133MHZ range ( one kit only )
    if you can wait until june ( around there ) the new 7XX series of Nvidia cards are coming out, or if you want to go whit AMD but thats up to you.
  8. #8
    Mar 2013
    31
    379
    if you look at the specs, 2133 ram is allot higher than 1600 and the performance increase is sometimes as little as 1%, and if the money is needed elsewhere, 1 ssd will be fine for starters. Most games will run just as good on a high end hdd, literally I have found 2 out of hundreds of games, in which case I just use steam mover to migrate it to my ssd.
    [IMG][/IMG]
  9. #9
    ROG Member Array
    Apr 2013
    8
    i actually just build a PC in that budget limit.
    with these specs:
    http://rog.asus.com/forum/showthread...untry=&status=
    i use a 21.5" Samsung monitor in 1920x1080 the PC is a monster, you can probably get the parts cheaper where you are, i bought these components in Danish currency and with the taxes and such, i'd say you can get a bigger monitor perhaps or a nice keyboard and mouse (i had these and are not in the budget).
    this pc runs Battlefield 3 with everything on ultra in 1080p at 60-70 FPS without getting stressed.
    hope this helps.
