Problem with installing new hard drive !!!!!!!
Braindamage
Hello guys,
I just bought a new hard drive and when i installed it , it appears to safely remove hardware. I did register the harddrive as a hard drive by formatting the drive and giving it a name.
Is there a way to remove that notification or the motherboard to see it as my regular hard drive. I have an ssd for the windows and now i bought a new hdd and i had this problem
maximus V formula, 3770k @ 4.8, evga 780 classified hydro cooper,corsair 750D, corsair ax860, corsair dominator platinum 16gb @ 1866,128gb 840pro samsung , 240gb samsung evo, asus xonar essence sound card stx
Watercooling: Ek nickel clear cpu waterblock, Ek D5 pump, EK 140 reservoir, ekwb fittings, 1 360mm black ice SR1 radiator, 1 280mm black ice SR1, 3 Noctua NF-F12, 2 Noctua NF A14, 3 Corsair AF140 quiet
8 REPLIES 8
Granamere
Which motherboard do you have?
Do you have all of the drivers for it installed?
OS: Windows 8
CPU: I-7 3770k
Cooling: NZXT Kraken X40
GPU: evga Titan Superclocked Signature
Motherboard: Asus Maximus V Extreme (BIOS 1707)
Memory: Corsair Veneance 16GB (2x8GB) DDR3 1866 (Timing 9-10-9-27)
Sound Card: built on motherboard or Logitech g930
PSU: Corsair AX1200i
Case: Rosewill THOR V2
Chino
Level 15
Get into the BIOS and navigate to the Advanced tab. Look for SATA configuration. Look for the SATA port that your hard drive is connected to. Selec the Hot Plug option and disable it. Save and restart.
i cannot see the drive in the bios but everything is disabled already what should i do??
Braindamage
i have maximus v formula 3770k hdd: caviar black 500gb
THanks Chino once again 🙂
HalfBit
Dude,
You need to give us more info to help you out:
HD model/size/manufacturer?
Motherboard Model?
SO/Windows version?
Motherboard port used?
Primary HD model/type?
Braindamage
I solved the problem!! Thanks guys 😛
I changed to the sata from intel chip not that from asmedia and it worked out
Only intel sata connections you can manage through bios
Thanks again!!
pcunite
See this thread about removing hot swap when using the Windows driver
i5-3570k | V Gene | HD 4000 | Crucial M4 256GB | Fractal Design Mini | NEC 2490WUXi2
HiVizMan
Level 40
OP please ensure that your have installed the driver on the INTEL sata controller.
Which SATA port did you use to fit the hard drive?
