Results 1 to 4 of 4
    New ROGer Array
    May 2013
    2
    Memory issues Max V Formula
    Built brand new system with a Max V as base. Gave me problems from the first boot. Initially blamed the Corsair SSD as they have known problems. Replaced tried with Seagate HDD and then a Kingmax SSD. But the problems persisted.
    System was generally flaky failing to install drivers and windows updates successfully, and would frequently BSOD with the most common error being memory management.
    Found Trident X profile in the bios and selected that =failed to boot to post, removed battery to clear and get to boot.
    So I decided to run memtest86 as suggested by this site.
    Both sticks in = >100 000 errors.
    tested each stick separately in the slot closes to CPU = 0 errors therefor Ram is OK
    Tried 1 stick in any other slot = errors
    Now running smoothly with 1 stick.
    From this I think the Motherboard is faulty.
    Any suggestions or fixes before I return it.
    Intel Core I7 3770K
    Maximus V Formula
    G.Skill Trident X F3-2400C10D-16GTX (2x8GB)
    Gigabyte Geforce GTX670 OC 2GB
    Seasonic M12II 750W
    Kingmax SMP35 Client 120GB (Boot)
    Cosair Force Series GS 240GB
    Seagate Barracuda 2TB
    ROG Guru: Grand Master Array
    Oct 2012
    339
    15,255
    Welcome to the Republic of Gamers, Jack D.
    Try testing each module individually in the DIMM_A2 slot. Any errors?
    New ROGer Array
    May 2013
    2
    My mistake it was running in the A2 slot
    Tested both modules in the A1 slot with no errors, both B1 & B2 show errors.
    Dec 2011
    354
    25,742
    There we go.
    RMA time for that motherboard.
Tags for this Thread
