Results 1 to 5 of 5
    ROG Enthusiast Array
    Jan 2013
    42
    Unhappy sound driver problem ! PLEASE HELP !
    I have this problem with sound drivers since windows 8!
    I can't install any via audio driver except 6.0.01.1600a from c_man's thread ! I got an error that says "no any hd audio devices found" and the installer continues but after restart the driver remains windows default .
    6.0.01.1600a driver is working but the sound quality on this driver is just poor compared to newer ones and I can't install any other driver, not even officials drivers from asus website !
    I tried everything including refreshing my pc in windows 8 settings !
    What do you advice me to do ?
    New ROGer Array
    Oct 2012
    13
    2,441
    what is your laptop model? i think it is G75VW right?
    Jan 2013
    42
    That's right !
    Feb 2011
    27
    I have similar problem. Somehow I lost the VIA deck (or what ever it's called), so I decided to reinstall the latest drivers. I uninstalled all the old ones and tried every VIA driver there is, but all I get is an error which says that some elements were not installed, install failed. So now I'm running the default Win 8 Microsoft HD drivers, but I need my EQ settings.
    No idea how or why the old VIA drivers broke down or why none of the available drivers can't be installed. I just can't figure out why I can't install any driver. I even tried to uninstall the default HD drivers and the tried to install VIA ones, but no game.
    Any ideas? Can it be the nVidia drivers as I installed the new 320.14 beta drivers and I think the VIA deck got "lost" after I rebooted my laptop after some days after that.
    G75VW
    OS: Win 8 Pro 64bit
    EDIT: I tried those driver's from c_man's thread and I get the same error:
    Fail to Installed components :
    VIA HD Audio Codec Driver v10.6.00.30.120710
    And then "Some components couldn't be installed, check the log", but I can't find any via install logs.
    Jan 2013
    42
    I finally managed to solve my problem !
    Here's what I did:
    I uninstalled all audio drivers from device manager and I made sure that there isn't any via program installed and that I updated all my drivers with driver scanner from uniblue . After restart, the 6.0.10.1700 driver showed up and now I am happy
