Page 1 of 2 1 2 LastLast
Results 1 to 10 of 12
    Boofus
    Guest
    Heat concern, and also limited voltage.
    So im wondering i have a string of capacitors to the left of my CPU that get really really hot under load should i be worried or should i just not worry about them like i have been. and also with this Asus M3A78 im limited on the CPU voltage amount to +50mv +100mv and +150mv. which i top out at about 3.35Ghz. and also when overclocking by CPU multiplier my ram speed drops below stock. as i have a Amd Athlon 64x2 5400+ Black edition that i have overclocked by fsb also to bump ram speeds up.
    TeamROG Folding@Home Array ottoyu34 PC Specs
    ottoyu34 PC Specs
    MotherboardMaximus IX Hero
    ProcessorIntel Core i7 7700K
    Memory (part number)Trident Z RGB (F4-3600C16D-16GTZR)
    Graphics Card #1ROG Strix GTX1080 Ti OC
    MonitorLG IPS LED 27"
    Storage #1Samsung SSD 850 PRO 1TB
    Storage #2Crucial MX300 525GB SSD
    CPU CoolerCorsair Hydro H115i
    CaseCorsair Obsidian 750D Airflow Ed.
    Power SupplyEVGA SuperNOVA 750 G3
    Keyboard Corsair Vengeance K65
    Mouse Logitech G502
    Mouse Pad Razer Destructor
    Headset/Speakers Logitech Z-2300 2.1
    OS Windows 10 Pro x64
    Network RouterAsus RT-N66U
    ottoyu34's Avatar
    Apr 2010
    805
    I believe you're talking about the CPU PWM, or the power regulators for the CPU.
    Usually they are rated tempertures over >100C, and it really depends if your board is built for overclocking using high-quality components. so YMMV.
    Yes seems like the board is limiting you.
    TeamROG Array V2-V3's Avatar
    Mar 2010
    11
    482
    Quote Originally Posted by Boofus View Post
    You dont have to worry about the capacitors getting to hot, they dont really need any cooling as they are not the source of the heat.
    the heat is coming from the voltage regulators under the motherboard heatsink, if you can get some mild airflow on the board cooler it will help a lot. but i doubt your board temps are anything beyond acceptable.
    for your RAM speed issue you should manually adjust the speed to lock it in or compensate for the drop in MHz.
    it is probably a divider that is being changed in relation to CPU speed or FSB.
    Boofus
    Guest
    Ive set the manual ram speed aswell. its when i usually use any multiplier under or over 14 it seems to drop. but as ive found a sweet spot for my system at 230x14. but i think i should be able to run much higher than 3.35ghz i can get it to post at 3.4ghz but then doesn't make it to windows. and Amd overdrive wont let me clock with fsb.
    Mar 2010
    11
    482
    Have you tried more or less voltage on the CPU @ 3.4GHz
    Windows loading puts a big load on the CPU, if the voltage is too high it will overheat and the system will crash. not enough voltage and the CPU is unstable and will crash.
    Boofus
    Guest
    Quote Originally Posted by V2-V3 View Post
    Ive gone to the max voltage and the lowest voltage and i don't think my CPU would overheat. my load temperatures are between 40-45c with lowest fan setting in about a 80 degree room. when i max all my fans out it drops below 40c at 1.392v right now stable, at 3220.2mhz and i can get more voltage up to like 1.5v with the amd overdrive but it doesn't allow me to control my fsb, only multipliers. and i have a Amd RD770 north bridge and a Amd SB700 south bridge
  7. #7
    Mar 2010
    11
    482
    Is there a CPU Overvoltage jumper on the board? if there is it will enable higher CPU Vcore options in the bios.
    also are you running the latest BIOS?
  8. #8
    Boofus
    Guest
    I am running the latest bios and no there is no CPU voltage jumper, but as of right now im running a phenom II 940 at 3.6Ghz. with no issue. but im dreading falling back to my 5400+
  9. #9
    Mar 2010
    11
    482
    If you are willing there is a modification for your motherboard that will allow higher CPU voltage, If you are interested in soldering 2 wires onto your motherboard I can post a guide for you to follow. I believe with the Voltage mod you can reach up to 1.9 volts
  10. #10
    Boofus
    Guest
    oh yeah i would like to try that mod out im not really worried about breaking anything.
