dual monitor setup
abirli
Hey Rog,
I have an opportunity to grab another dell ultrasharp 2407wfp on the cheap, and i was wondering if i should go for it. I got this monitor as a graduation gift in 2007 and its been perfect. now i want to maximize my gaming experience and grab another one if it warrants it.
Do you think i should pass this buy or snatch it up? i currently use my 55" lg LED to game but 2x 24" monitors is soo sexy and would give me reason to use my sli titans!
thoughts?
9 REPLIES 9
kkn
Level 14
you would only use 1 monitor in game and mabye the other to have monitor programs or other things on it.
or else your "cross" would end up in the middle of the 2 monitors.
if you understand what i am going for here?
for gaming its either 1 or 3 monitors ( 3 for "surround" gaming ).
if you want it grab it, all in all its up to you 🙂
abirli
yeah i got you, i was worried about that, i just may wait and continue on my 55" until i find a good set of 3
thanks
sectionate
Level 12
how does that input lag work out for you
Crosshair IV 1090T 4093.7 - Crosshair V FX - 8350 Batch # 1243PGT 4.422MHz - 4816.08 MHz 1.5v - GSKILL F3-14900CL9D-8GBSR(x2)1087.6 11-12-10 1.5volts - ViewSonic VX2439wm - Acer GD235HZ - SyncMaster P2350 - PowerColor Red Devil RX 480 8GBD5-3DH/OC - Current Mode: 5760 x 1080 - (retired) ASUS GTX660DC2O2GD5 - Nvidia 3D Vision Wired - HAF 932 - Corsair HX850 - Corsair H100i - latest quakelive.com - Day thirteen 60fps - as always I'm powered by Futurelooks.com
kkn
Level 14
depending on the TV sectionate.
most new tv's have under a millisec lag from pc to screen.
only way to meshure it is whit a monitor and a tv and a camera/photo camera while doing a clock timing on it.
sectionate
Level 12
I think it would be noticeable on a 55 inch, unless your just browsing facebook with it ;0
Adhy_Dharma_FN
are "radeon hd 6770" support 3 monitor?
Next Build
- AMD Vishera FX-8350
- AMD Radeon HD 7870
what version?
I should think so, I had a triple monitor set up on my 3870.
i dont notice any lag on my tv.
