06-02-2013 08:33 PM - last edited on 03-06-2024 08:59 PM by ROGBot
06-02-2013 09:01 PM
06-02-2013 09:25 PM
Boosted_R wrote:
Sounds like one of your fans isn't working...... can you feel air coming out off the fan outlets ? Keep in mind 1/3 of the right side (looking at the vents) their isn't a vent, its symmetrical for aesthetics only.
06-02-2013 09:08 PM
06-02-2013 09:30 PM
dstrakele wrote:
Your overheating GPU is downclocking, reducing your FPS.
1) Blow out fan intakes and exhausts with compressed gas. Open the bottom and blast the fans. If this fails to return temperatures to normal levels, you will have to:
2) Repaste the processors (CPU and GPU) .
The thermal paste used to aid heat transfer from the processors to the heatsinks loses efficiency over time. It is normal for a gaming rig to require a repaste after 2 years. If you don't feel comfortable with the disassembly required in this task, find someone qualified to do the job for some cashola....
06-03-2013 03:22 PM
06-03-2013 07:37 PM
Boosted_R wrote:
its not the thermal paste, its too severe..... i'm pretty sure one of the fans have failed or stuck....... I had an old dell D830, where dust got between the blade and housing and the fan wouldn't spin when I turned it on....... Run HWiNFO64.... run sensors and see what RPM the fans are spinning.
I am at 40C (GPU) and 44C (CPU) currently:
CPU Fan: 2176RPM
GPU Fan: 2604RPM
06-03-2013 07:39 PM
