06-04-2013 09:30 AM - last edited on 03-05-2024 11:57 PM by ROGBot
06-05-2013 01:31 PM
06-05-2013 06:32 PM
06-08-2013 03:44 PM
Djask wrote:
Honestly you wouldn't tell the difference, even if you get faster speeds. If you still want to buy one, I'd recommend the Intel® Ultimate N WiFi Link 6300 a/g/n 3x3 or the Killer™ Wireless-N 1202 a/g/n 2x2 MIMO.
06-08-2013 09:20 PM
06-09-2013 06:15 AM
tkolarik wrote:
I have the Intel Centrino Ultimate N-6235. It has Bluetooth 4.0 and can receive 2 streams on either 2.4 or 5 ghz band. Not had a single problem with drivers but you must uninstall the Atheros ones first. The 6300 has 3-streams but you give up Bluetooth. And with the crappy sound system in the G75, I use my Bluetooth headset all the time. Djask is wrong if you have the BestBuy version. It doesnt allow 40mhz channel bonding widths, and you will notice the difference!!!
06-09-2013 01:52 PM
07-18-2013 05:57 PM
