Page 1 of 2 1 2 LastLast
Results 1 to 10 of 12
    ROG Member Array
    Nov 2012
    14
    I am freaking out. Water inside laptop?
    I came home a few days ago and after I opened my g75 I freaked out because on the keyboard and all over the screen there was
    what looked like water. It was a clear liquid that had no smell or taste (I later tried it).
    Anyways I cleaned my laptop and yelled at my little brother thinking that it was his doing.
    The crazy thing is that this has happened a few times already and it is scaring me. How is it still working if it has water inside of it and how the hell does it only come out if the lid is closed?
    ROG Guru: Orange Belt Array Apexing's Avatar
    Aug 2012
    15
    306
    dunno how it got in there, but remove battery. and stick the whole laptop into a bag full of rice, leave it there for a week or so, turn the bag over once in a while. should get rid of the moisture/liquid, tho the internals might alread be getting rusted. so I would also remove the back panel to have a look.
    ROG Guru: Brown Belt Array nikosa43's Avatar
    Jun 2012
    73
    1,014
    Most possibly is from condensation of water from the air. Do you live in a high humidity country? Do you use air conditioning and bring periodically room temps low? I guess is something related to that and high humid air is entraped between screen and keyboard, but for this to built up in water, room temp has to go down drastically. If it is something like this try to open windows in the room so fresh air balance the air inside.
    ROG Member Array
    Nov 2012
    14
    I actually leave the windows open. Would you suggest I keep laptop open?
    Jun 2012
    73
    1,014
    If you keep your screen open I guess you will not notice it again in such extreme . But if it is humidity of the air (basement?), you have to find a permanent solution not only for devices but for yourself too. Do you have big up and downs of temperature there?
    New ROGer Array
    Oct 2012
    13
    2,441
    donot power on system and use hairdryer and wait to all dry, also you can send to service center.
  7. #7
    ROG Member Array
    Nov 2012
    14
    I live in vancouver and I live on the third floor of a house. Though it has been kind of humid the past few weeks.
    alternating rain and sun but I had my window open because it was so hot sometimes
  8. #8
    Jun 2012
    73
    1,014
    If you use hair dryer do not approach the dryer very close to the laptop. Very high temperatures will destroy sensitive plastic components, such keys from keyboard. Trust me I already have destroyed a a laptop keyboard like this. Blow hot air from a distance please
  9. #9
    ROG Member Array
    Nov 2012
    14
    It seems to be working. Is it bad to keep it working?
  10. #10
    Jun 2012
    73
    1,014
    Quote Originally Posted by gravehopper View Post
    I live in vancouver and I live on the third floor of a house. Though it has been kind of humid the past few weeks.alternating rain and sun but I had my window open because it was so hot sometimes
    That explains a lot. I thing weird weather conditions is to blame for that. If you have the same conditions again it's good to have a cheap fan in the room just to move the air and not standing still. Also keep screen open for not having trapped air inside. The last goes for anything you have closed, like drawers or capboards. Leave them slightly open
Tags for this Thread
