Results 1 to 10 of 15
Thread: Shock from metal parts- G46VW
06-27-2013 09:42 AM #1
Hey Guys,
So I finally got my first laptop, a couple of days ago, A G46VW.
Its a very cool laptop. But Since the first time I used it the Aluminium palm rests of the laptop give a electric sensation when the laptop is connected to the grid. So I waited a couple of days and got a belkin power surge protector. And that didn't help either.
I was looking up things online and so far the only reason I could find is that there is no grounding. But the laptop comes with a 3pin plug so I assume thats not the problem (also I am assuming that my plug point has proper earthing).
So is this common? Is it harmful (to me or more importantly to the laptop)?
Also will this cause any damage to the USB devices I plug in, like my XBOX controller?
ASUS G46VW-BSI5N06
Intel Corei5-3230M | nVidia GTX-660M 2GB GDDR5 | 8GB DDR3 RAM | 750 GB 5400 RPM HDD | 1366x768 14" Screen
06-27-2013 10:16 AM #2
That is quite strange. Are you living in an area with known good electrical networks? If your house is older (in the states), it may not be properly grounded. Does the laptop "zap" you when it is running on battery? If not, then I would say that the issue is in the transformer. I would suggest that you check either your electrical grounding system, and/or your transformer.
I am disturbed because I cannot break my system...found out there were others trying to cope! We have a support group on here, if your system will not break, please join!
http://rog.asus.com/forum/group.php?groupid=16
We now have 178 people whose systems will not break! Yippee!
LINUX Users, we have a group!
http://rog.asus.com/forum/group.php?groupid=23
06-27-2013 12:15 PM #3
Thanks for your reply. I actually live in India, and well like the country, the electric networks is in works. And I cannot say anything for certainity regarding the grounding of where I live right now, as I am in a hostel on campus. I guess its a fault at my end only.
It doesn't give me shocks or anything, but just a sensation, slight tingly feeling when I touch the aluminium. The only thing is I am worried if this will damage my laptop or my accessories. Any idea about that?
ASUS G46VW-BSI5N06
06-27-2013 12:42 PM #4
- Join Date
- Apr 2013
- Reputation
- 10
- Posts
- 20
Maybe what you feel it's just a high frecvency vibration, transmited through the metallic surface, and not an electric shock. The vibration can be caused by the hdd, or the fans.
06-27-2013 03:23 PM #5
I don't think that it will, or something would have happened. I hadn't thought about the high-frequency transmissibility of the fans, though that wouldn't likely give a tingly feeling. Also, if it is the fans, then the tingly feeling would continue even on battery. If it doesn't, then the electrical network could be to blame - in that case, I don't know if it would damage anything, since I am by no means an electrical engineer - if you know any of those, they might be able to help you more.
06-27-2013 03:30 PM #6
That's not good you experience the tingling only when plugged in. If your outlet is not properly grounded, it has the potential to damage your laptop and YOU. We don't want to see you written up in the Times of India as ANOTHER case (see http://articles.timesofindia.indiati...extension-cord). Best get that checked out.
Also read http://en.community.dell.com/support....aspx#17467555.
A surge protector cannot protect against improper grounding.Last edited by dstrakele; 06-27-2013 at 09:58 PM.
G74SX-A1 - stock hardware - BIOS 202 - 2nd Monitor VISIO VF551XVT
06-27-2013 04:01 PM #7
- Join Date
- Apr 2013
- Reputation
- 10
- Posts
- 20
The grounding ends in the transformer. The laptop itself it's not grounded, he receives 20V.
The probable reason why he feels only when connected to the grid it's that little bit of extra power to all laptop components.
I've felt the same sensation on an MBP, and it was from the hdd.
Just my oppinion...
06-27-2013 08:26 PM #8
- Join Date
- Nov 2011
- Reputation
- 16
- Posts
- 40
Was your laptop modified? If so, maybe a ground wire or other electrical wire isn't connected properly?
06-28-2013 08:08 AM #9
06-28-2013 08:13 AM #10
