More RAM @ same speed = lower score?
Hartacus
I had two sticks of a quad channel kit in and get 632. I install the other two sticks with everything on the same settings and I get 20 less points for 612? I tried it several times too. Any ideas?
HiVizMan
Level 40
Yip the system you are using works best in pure dual channel.
Adding the other two sticks add to the work overhead and as a result runs slower in a benchmark, simply because it now has four banks to populate and refresh instead of two.
megastarkey
Would one stick perform better on my M6Hero?
MEGAStarkey
Intel i7 4770kOC @ 4.6 / 1.25v - Maximus VI Extreme - 16gb Team Xtreem @2400
Gigabyte R9 290x Windforce OC
Intel i7 4670kOC @ 4.2 - ASUS Z97i Plus - 8gb Crucial Ballistix@1600
ASUS 660GTX
AMD FX8350OC @ 4.8 Ghz Stable - Crosshair V Formula-Z -8gb Crucial Ballistix @1600
ASUS 660GTX
Probably not, because then you're only running single channel.
2 small fast sticks is what ya need 🙂
