Page 2 of 8 FirstFirst 1 2 3 4 ... LastLast
Results 11 to 20 of 76
  1. #11
    ROG Enthusiast Array
    Jun 2013
    43
    hi ZKa17
    It's done one pass with no errors, but I will let it run for the night . As I mentioned before, i'm very new to this and have very little knowledge of bios ram settings etc I purchased all the parts and got a pc shop to set it up, but after reading the forums for the last couple of weeks I started to think this system might be a bit too complex for him. When I mentioned things like trim ect he said he'd never heard of it so I don't know if it's even set up properly. It seems to work, but it just seems very unstable. I have run real bench and the stress test, and it said that the computer was stable, it just seems to go wrong sometimes when its turned on and 4 out of 5 times when using sleep .
    Thanks for all your help
  2. #12
    Jun 2013
    43
    Hi Arne
    it was 2 16g kits cmd16gx3m2a1866c9 I'm using al suite ii cpu at 4.2 ram at 1447 ? I've tried removing the suite and set the cpu at 4.4 and ram at 1866 from the setting in the forum if anything it was slightly more unstable
    thanks for your help
  3. #13
    ROG 師傅 Array Arne Saknussemm PC Specs
    Laptop (Model)Laptop?...No way! (Model?...Jun Amaki...yes way!)
    MotherboardROG ZENITH EXTREME
    ProcessorTHREADRIPPER 1920X
    Memory (part number)F4-3200C14Q-32GVK
    Graphics Card #1GTX Titan X
    Graphics Card #2SLI is dead to me
    Graphics Card #3Tri SLI is even dead to Nvidia
    Graphics Card #4Quad SLI is dead to everybody especially my credit card
    Sound CardXonar Essence STX
    MonitorASUS ROG Swift PG279Q
    Storage #1Samsung 950 PRO
    Storage #22x OCZ VERTEX 3/2x WD Caviar Black 500GB / 2x WD RED 2TB
    CPU CoolerCustom Loop: Dual D5s, Dual Alphacool Monsta 480s, XSPC Raystorm Neo TR4, EK TitanX WaterBlock
    CaseNope!...Phobya Bench...let it all hang out man!
    Power SupplySeasonic SS-1200XP3
    Keyboard Logitech G810 or Fender Rhodes Electric Piano (MKI 73)
    Mouse G502 or Speedy Gonzalez...not Mickey...don't do Disney!
    Headset ...firmly on neck
    Mouse Pad Mouse don't got his own pad man...lives with me
    Headset/Speakers Edifier Spinnaker...or you mean the speakers in my head...man too many voices to name them all
    OS Win XP, 7, 8, 8.1 and Windows 10 Spyware Edition
    Network Router56k modem
    Accessory #1 Umm...nice tie?
    Accessory #2 Err...belt?
    Accessory #3 3 accessories?! I'm not a girl!!
    Arne Saknussemm's Avatar
    Apr 2012
    481
    13,383
    Hmm OK I was wondering. Running two kits even though they are "identical" can lead to problems. A single kit is binned to work as just that...a single kit....adding another might seem like a logical match but the chips that make up the other kit are similarly binned to run together but maybe at slightly different sub timings etc. etc. so compatibility between kits is certainly a harder thing to set up and in worst cases not possible.
    For the best possible chance of running the two kits I would take them out completely and then separate the kits....you can do this by the serial numbers on the sticks themselves. You could then try running just one kit on the red slots. If all is fine you could then add the second kit to the black slots....
    Maybe have a read through this http://rog.asus.com/forum/showthread...untry=&status= you might find it useful in setting up the ram and maybe tweaking things like voltage and DIGI+ settings to give yourself a better chance at stability.......
  4. #14
    Jun 2013
    43
    I didn't no this, when I spoke to the guy in the shop I said I might go for the 64g just to fill the board lol he said just do it 16g at a time so I did. started with 16g put another 16g in 2 days ago, but I must say ive had this problem since the day I picked it up 2 weeks ago.
  5. #15
    Jun 2013
    43
    I also have problems with the corsair link software it works one minute not the next but I've unplugged it and removed the software thought that had cured it as it came out of sleep 3 times in a row but then went back to freezing. well its not freezing the mouse moves I just cant click on any thing
    Thanks for the help guys
  6. #16
    Apr 2012
    481
    13,383
    Yes AI siute and corsair link are a bit special shall we say. Neither of them likes other programs of that type installed and if you had both I should not wonder they gave you problems.
    By the way after uninstalling AI suite you can have stuff left over...there is a batch file for removing completely...http://rog.asus.com/forum/showthread.php?28319-AI-Suite-II-uninstall-cleaner
    OK I see the RAM are 8GB sticks and you have 4 of them right? all on the red slots? going up to 64GB with 4 kits I think would be a miracle if it worked!
    Maybe try setting up what you have now entirely manually....how to at end of that guide....
  7. #17
    Jun 2013
    43
    yes 4 sticks, all in red slots. ill run the memory test for the night and ill remove the AI suite again in the morning and try the manual setting. I'm a bit nervous when it comes to the manual settings as i no nothing about ram timings and settings etc
  8. #18
    Jun 2013
    43
    sorry at the end of what guide
  9. #19
    Apr 2012
    481
    13,383
    RAM timings is still something I am learning about every time I go back to them....but copying the timings from the XMP profile and entering them manually is not hard.
    If you have a USB pen formatted FAT32 and you press F12 in BIOS it saves a screen cap to the pendrive so you can post up what you have in BIOS here even....
    This guide http://rog.asus.com/forum/showthread.php?25510-Rampage-IV-Extreme-RAM-Guide&country=&status=
    If the steps are unclear let me know and in any case there are plenty here who can help you if you have any doubts etc....
  10. #20
    Jun 2013
    43
    thanks so much for your help feeling a bit better now was pulling my hair out today lol
