Page 7 of 8 FirstFirst ... 5 6 7 8 LastLast
Results 61 to 70 of 76
  1. #61
    ROG 師傅 Array Arne Saknussemm PC Specs
    Laptop (Model)Laptop?...No way! (Model?...Jun Amaki...yes way!)
    MotherboardROG ZENITH EXTREME
    ProcessorTHREADRIPPER 1920X
    Memory (part number)F4-3200C14Q-32GVK
    Graphics Card #1GTX Titan X
    Graphics Card #2SLI is dead to me
    Graphics Card #3Tri SLI is even dead to Nvidia
    Graphics Card #4Quad SLI is dead to everybody especially my credit card
    Sound CardXonar Essence STX
    MonitorASUS ROG Swift PG279Q
    Storage #1Samsung 950 PRO
    Storage #22x OCZ VERTEX 3/2x WD Caviar Black 500GB / 2x WD RED 2TB
    CPU CoolerCustom Loop: Dual D5s, Dual Alphacool Monsta 480s, XSPC Raystorm Neo TR4, EK TitanX WaterBlock
    CaseNope!...Phobya Bench...let it all hang out man!
    Power SupplySeasonic SS-1200XP3
    Keyboard Logitech G810 or Fender Rhodes Electric Piano (MKI 73)
    Mouse G502 or Speedy Gonzalez...not Mickey...don't do Disney!
    Headset ...firmly on neck
    Mouse Pad Mouse don't got his own pad man...lives with me
    Headset/Speakers Edifier Spinnaker...or you mean the speakers in my head...man too many voices to name them all
    OS Win XP, 7, 8, 8.1 and Windows 10 Spyware Edition
    Network Router56k modem
    Accessory #1 Umm...nice tie?
    Accessory #2 Err...belt?
    Accessory #3 3 accessories?! I'm not a girl!!
    Arne Saknussemm's Avatar
    Apr 2012
    481
    13,405
    OK that's better...lets see if a single kit sorts the problem...fingers crossed
  2. #62
    ROG Enthusiast Array
    Jun 2013
    43
    I just wanted to check is the dominator platinum 64gb 2400 ok for the rampage iv extreme
  3. #63
    iron man Array kkn's Avatar
    Aug 2011
    243
    6,112
    as long as its quad ( 4 ) channel memory then yes, if now then no ( from what i know of but arne would know better then me )
  4. #64
    ROG Guru: Diamond Belt Array Zka17's Avatar
    Mar 2012
    199
    8,358
    Quote Originally Posted by ted west View Post
    If it's a single quad kit, then it's fine! It will be very expensive though... you may want to look around GSkill RipjawsZ kits too...
  5. #65
    Jun 2013
    43
    thanks guys ill check them both out had a look on the corsair site but it doesn't seem to tell you if its quad core or not ?
  6. #66
    Apr 2012
    481
    13,405
    64GB of anything is going to be a stern test for the CPU's IMC and 64GB at 2400 more so. I'm still not sure why you want so much RAM but you have to be aware that Intel guarantee 1600MHz nothing more. Anything above is OCing and is territory for disappointment the higher you go in frequency and the greater the load (more RAM) that you put on the IMC.
    I would seriously advise 2133 MHz G.Skill Z series if you want to go for 64GB. http://www.gskill.com/en/product/f3-17000cl11q2-64gbzld
    this does not have the tightest timings but that will only help.
    Personally I would go with less RAM....fill the red slots and get tighter timings http://www.gskill.com/en/product/f3-17000cl9q2-32gbzh
  7. #67
    Jun 2013
    43
    Hi Arne
    I have to admit I have very little knowledge of ram, Im trying to build the best pc I can and trying to get the best of the best components. I do a little bit of video encoding but that's about it. I no I don't need such a beast of a pc lol, but I love it. im also loving this forum I think ive learnt some thing new every day so far. and think I will come down to 2133
  8. #68
    Apr 2012
    481
    13,405
    Heck, well I don't want to be a party pooper and if you want 64GB at 2400 then you go for it! But that is a bit of a gamble on X79 and I just wanted to make sure you understood that. Or that getting it to run might require extensive tweaking and maybe voltages that would make the voltage-shy, like me, unhappy to run at 24/7.
  9. #69
    Dec 2011
    354
    25,742
    64GB is a big ask of any CPU's IMC. Yes they will do it, but everything needs to be right.
    One set of ram is a must here.
    Willingness to accept default frequency, and not expect as a right 64GB at the ram specified frequency.
    Post up how it goes.
  10. #70
    Jun 2013
    43
    Thanks for all your help guys. I'm waiting on my ram to arrive now, I have to wait for pc shop to rma my old ram. I think I'm going to start over, ie reformat set up raid etc as I'm not happy with the pc shops work, and I'm not sure if its been set up properly. ive noticed today that the graphics card is in slot 2 pcie x8. the card is an asus 660 ti oc. shouldn't this be in a pcie x16 slot. would be grateful for any advice
