Page 2 of 3 FirstFirst 1 2 3 LastLast
Results 11 to 20 of 24
  1. #11
    ROG Guru: Green Belt Array KPRage PC Specs
    KPRage PC Specs
    MotherboardMaximus V Gene
    Processor3570k
    Memory (part number)Vengance 1866 8Gb Ram
    Graphics Card #1Zotac GTX 1070 Mini
    Graphics Card #2ASUS R9 280 DC2
    Graphics Card #3Radeon 5850 HD
    MonitorASUS VZ27AQ
    Storage #1Samsun EVO 850 Pro
    Storage #23 1TB HDDs
    CPU CoolerH80
    CaseMerc Alpha
    Power SupplyTX 650 80 plus Gold
    OS Win 7/ Win 8.1/ Win 10
    KPRage's Avatar
    Aug 2012
    26
    572
    Quote Originally Posted by HiVizMan View Post
    Ask and ye shall receive so sayith the moderators.
    He he.. My first sticky thread! Yay!! Thanks Viz and, djdelirius..
    CPU: Intel i5 3570k OC'd to 4.6GHz @1.170V; Mobo: MVG; GPU: Zotac 1070 mini OC'd to +210MHz/+205MHz; Memory: 8GB (2X4GB dual channel) Corsair Vengeance 1333Mhz 9-10-9-T2; SSD: Samsung 840 pro; HDD: 1TB WD Green 6Gbps; PSU: Corsair GS 600w; Case: Bitfenix Merc Alpha:Hybrid Octane in progress; Cooler: Corsair H80 closed loop cooling @ high profile;
    Pre & Post Build Guide
    A lot of epic FAIL videos are made before one epic WIN video is made
  2. #12
    New ROGer Array
    Apr 2013
    3
    add a better Gpu ! and use a ssd as boot device, your pc will become a DRAGON !
  3. #13
    ROG Guru: Grand Master Array
    Oct 2012
    339
    15,247
    Very good work on the guide, KP.
    There's a simple method to further test the PSU by using a multimeter to measure the output on each rail. It does take time and a bit of electrical knowledge to do so. But most importantly, the will to work with electricity lol. Not sure if you want to add it to your guide.
    A good addition to the motherboard section is to inspect the CPU socket for bent or missing pins in Intel's case. Or inspect your CPU in AMD's case. It's a simple thing that many builders overlook. I also like to test the clipons for the RAM and PCIe slots just to make sure they snap into place and not too loose or broken. Then I'd proceed to inspecting the motherboard chokes and capacitors if there are any leakage or not soldered on properly.
  4. #14
    KPRage PC Specs
    Processor3570k
    MonitorASUS VZ27AQ
    CPU CoolerH80
    CaseMerc Alpha
    KPRage's Avatar
    Aug 2012
    26
    572
    Chino, Thanks for the info mate..
    Added your info. Thanks again mate..
    Cheers,
    KP
  5. #15
    KPRage PC Specs
    Processor3570k
    MonitorASUS VZ27AQ
    CPU CoolerH80
    CaseMerc Alpha
    KPRage's Avatar
    Aug 2012
    26
    572
    Quote Originally Posted by pavlos97 View Post
    Hey pavlos.. Welcome to ROG.. Have ordered my first SSD. Will be here next week.. GPU is not in the list for now.. Next up would be a killer RAM.. Then its gonna be blazing hot..
  6. #16
    ROG Member Array Lockques's Avatar
    Apr 2013
    20
    Up for this one!!!.. Nice.. keep on sharing!..
  7. #17
    ROG Enthusiast Array welshy46 PC Specs
    welshy46 PC Specs
    Laptop (Model)Some Asus i3 thing
    MotherboardAsus Maximus VI Formula
    Processor4770K
    Memory (part number)50862578 RevD
    Graphics Card #1Asus Strix 1070 oc
    MonitorAcer XR341
    Storage #1Samsung Evo Pro 256GB (OS)
    Storage #2Patriot blast 240GB & 480GB +NAS
    CPU CoolerCustom water
    CaseThermaltake View 27
    Power SupplyCorsair AXi 1200w ( had 3x 290x)
    Keyboard Cougar 700K
    Mouse Cougar 700M
    Mouse Pad Huge OverclockersUK desk mat
    Headset/Speakers 8yo £16 logitechs
    OS Windows 10 64bit worse than Vista
    Network Routerwhite one with flashy LED's not RGB
    welshy46's Avatar
    Nov 2013
    57
    things to do before building the system I have just finished.
    1. read this article
    Doh!
    Good read, I was asked the other day by a work colleague to spec a system for his son. Obviously started with a ROG board. all the cool cats are running Max VI formulas and have told him to get on this forum before he gets it and try to avoid the first build schoolboy errors.
    Board: MVIF
    CPU: intel core i7 4770k@4.8GHz
    GPU: R9 290x
    RAM: 16gb Corsair Vengence 2133MHz
    SSD: ROG RAIDR 240gb PCI-e SSD
    Case: Coolermaster HAF xb
    Cooling: custom water loop
    Monitor: Asus PB278Q
    My build log photo dump
  8. #18
    ROG Member Array
    Jan 2014
    23
    How to test before assembly if the CPU didn't come with a fan and the build is planned for full watercooling? Buy a basic fan just for the test I guess?
  9. #19
    iron man Array kkn's Avatar
    Aug 2011
    243
    6,129
    get a cheep CPU cooler for a few bucks.
    and some TIM.
  10. #20
    ROG Member Array IIIDefalt PC Specs
    IIIDefalt PC Specs
    MotherboardASUS Maximus VII Hero
    ProcessorIntel Core I7 4790k
    Graphics Card #1MSI GTX 970 4G Twin Frozr V
    MonitorSceptre
    Storage #1WD Black 1 TB
    Storage #2Samsung 840 EVO 250GB SSD
    CPU CoolerCooler Master Hyper 212 EVO
    CaseCooler Master Storm Stryker
    Power SupplyEVGA Super Nova 850
    Keyboard Cooler Master Devastator Green LED
    Mouse Cooler Master Devastator Green LED
    OS Windows 7 Pro
    Jan 2015
    11
    I will be referring to the build part of this once I start my build. Very helpful! thanks a bunch!
Tags for this Thread
