Page 1 of 2 1 2 LastLast
Results 1 to 10 of 12
    ROG Member Array
    Jul 2013
    11
    Cooling question
    Just wondering if the cooling fans pull air through the bottom or through the keyboard. Haven't been able to find anything searching. Also, is there any way to manually adjust fan speed?
    ROG Guru: Yellow Belt Array
    Jul 2013
    11
    157
    Im pretty sure they pull air from the keyboard area. Try using HWinfo to control the fan speed.
    New ROGer Array
    Oct 2012
    13
    2,441
    i think asus laptop can not control fan speed.
    New ROGer Array Zygomorphic's Avatar
    Mar 2012
    176
    4,761
    The fan speed is set via thermometers in the BIOS, so it goes up and down as necessary. You shouldn't need to play with it, as it already balances cooling with performance. It pulls the air in through the speaker grille above the keyboard, and so you don't need a cooling pad to run the laptop at maximum.
    I am disturbed because I cannot break my system...found out there were others trying to cope! We have a support group on here, if your system will not break, please join!
    http://rog.asus.com/forum/group.php?groupid=16
    We now have 178 people whose systems will not break! Yippee!
    LINUX Users, we have a group!
    http://rog.asus.com/forum/group.php?groupid=23
    ROG Member Array
    Jul 2013
    20
    Quote Originally Posted by Zygomorphic View Post
    I don't see any speaker gills above keyboard on my G750
    ROG Member Array
    Sep 2013
    11
    Get a flashlight and look underneath your screen where the hinges of the monitor are. There are speaker grills attacked at the back of the main body there and at the bottom of the monitor itself. They are very well hidden
  7. #7
    ROG Guru: White Belt Array kingfish's Avatar
    Sep 2013
    11
    116
    so no need to buy one of these cooling pad for laptops???
    G751JT | 24GB | 2 x 1TB HDD | Nvidia GTX 970M | Windows XP
  8. #8
    ROG Guru: Yellow Belt Array Flea0's Avatar
    Jun 2013
    21
    211
    yep. the g750 doesn't take air in from the bottom, so it can do heavy gaming while sitting on the table without any clunky cooling pads. That's why the JH has taller feet, it gives the laptop just the clearance it needs. without making a habit out of it, you can even put it on the bed to watch a movie if the exhausts aren't obstructed.
    ASUS G750JX -- i7-4700 - 16GB - 128GB 840 PRO SSD + 1TB HDD - Nvidia GTX 770M - 120Hz 3D glossy display
  9. #9
    ROG Member Array
    Sep 2013
    11
    Nope... Actually as far as I can tell this may be the first laptop I have ever had that I am willing to lay on my bed (for short periods of time) without fear of causing it to overheat due to the intake placement. Juts remember to keep the rear heat outports free and open. I even ran a few experiments on m JW to find the best way of cooling the laptop during benchmarks and I found nothing helped keep it cooler by way of elevating it or putting fans under it. I even set it on a stack of towels and ran a 30 minute benchmark to see if it would heat up due to lack or airflow on the bottom and there was no change. That was when I started to do research on where the air intakes where. However, if your cat comes up and layes on your keyboard you might be in trouble.
  10. #10
    Jun 2013
    21
    211
    yeah, leaving it on with the screen closed is probably not a good idea from that point of view.
