07-17-2013 11:38 PM - last edited on 03-06-2024 02:35 AM by ROGBot
07-18-2013 01:58 AM
Pitcher@asus wrote:
when you remove battery and only plug ac adapter, is it able to powe on? if not, i think you will sent to service center to check boad.
07-18-2013 02:54 AM
07-19-2013 02:14 AM
fakunchas wrote:
Normally, is the connection itself on the MB that with time becomes loose or simply fries!.Tell your friend to check the MB in that zone.
Make sure it is not RAM related. I had a casa where the freaking laptop (not an ASUS) simply would not power on because of a fried RAM stick.
Whatever happens, when you know the result, share with us!
07-19-2013 09:28 AM
07-19-2013 06:39 PM
cl-Albert wrote:
If your DC jack isn't loose and looks normal, I'm guessing it isn't the problem, but you might still want to try it if you don't have other options.
1. It's a bad sign for the motherboard if your AC adapter light blinks only when you plug it into the notebook since it also tells me something is shorting out on the motherboard.
I would try to first get your AC adapter light to stop blinking if possible by unplugging everything you can and making sure there isn't something else causing the problem.
Or, if you can easily remove the motherboard, plug in the AC adapter to confirm the light is still blinking with only the motherboard (put the motherboard on a non-conductive surface, of course).
If the AC adapter light stops blinking when you plug it to only the motherboard, you can try to slowly reassemble the notebook and hopefully catch the problem/problem part.
If the problem appears to be with the motherboard (my guess), it may not be easy to fix, but inspect the board for any damaged/burned (easily replaceable?) components, etc. that could be causing the problem.
Well, I'm not all that familiar with repairing motherboards since we usually just replace them over here, so you may want to get more opinions about it if necessary.
2. You may not be interested in going this route, but if you didn't already know, just wanted to remind you that you can contact U.S. ASUS support about sending in the notebook for out-of-warranty service if you prefer by checking this contact page.
If you decide to send it in, try to make sure parts are still available though and find out what happens if they aren't.
3. You may be aware of this already too and everybody is different, but personally I don't like putting too much money into an older out-of-warranty system and would prefer to save for a newer (faster) system with warranty if possible. If you didn't already know, there are ways to connect your hard drive to a different system to access data if this makes any difference.
Good luck!
07-22-2013 09:46 AM
02-11-2014 04:15 AM
